Dark green 90 Posted August 19, 2007 Share Posted August 19, 2007 Hi Guys, I have recently been experiencing steering wheel wobble at speeds between 40 and 50, checked tyre pressure, balance weights and no lumps of crud stuck to rims It doesnt always happen which is puzzling and not at any other speeds either Any thoughts ? Yours, shook to bits... Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 20, 2007 Share Posted August 20, 2007 Hi Guys,I have recently been experiencing steering wheel wobble at speeds between 40 and 50, checked tyre pressure, balance weights and no lumps of crud stuck to rims It doesnt always happen which is puzzling and not at any other speeds either Any thoughts ? Yours, shook to bits... Panhard rod bushings and swivel pin preload are the first places to look. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 20, 2007 Share Posted August 20, 2007 Also check UJs on front propshaft for slop which gives the same symptoms. Mo Quote Link to comment Share on other sites More sharing options...
Escape Posted August 20, 2007 Share Posted August 20, 2007 Have a friend move the wheel left to right with some force while standing still and observe Panhard and other rods, chances are you'll see unusual play at one of the bushes. With mine it was the top Panhard rod bush, don't mess around with polybush etc, OEM does the best job. Quote Link to comment Share on other sites More sharing options...
Dark green 90 Posted August 25, 2007 Author Share Posted August 25, 2007 Thanks Guys Quote Link to comment Share on other sites More sharing options...
