garrycol Posted October 24, 2005 Share Posted October 24, 2005 The heater in my freelander has a very small leak in either the matrix or the connecting pipes. It is very small - enough to smell but not enough to see or to reduce coolant levels. The carpets is not damp but when you park on a hill a drop or two of coolant will fall into the front rubber mats. At this stage I would prefer not to pull the matrix out and as it will be heaps of work and the leak is still very small. I want to try a radiator sealant first. I am not going to use Bars Leak as it likely to clog up a lot of other things like the radiator. Years ago I used a product called Chemical Weld which is not a radiator sealant but is designed to fill small non structural head cracks but it also worked well on sealing other leaks. Any other thoughts would be appreciated - I do realise the matrix will probably have to be replaced but would prefer it to be later. Cheers Garry Quote Link to comment Share on other sites More sharing options...
jules Posted October 25, 2005 Share Posted October 25, 2005 I have use these products on external damage to radiators and they've lasted for years without trouble. I would try the putty's there good I carry laods of diffrant make ones when racing to use for emergency repairs. I fixed my disco 2 when she had a 4mm hole in a thermostat hosing with it so a pinprick hole should do a perminate fix fine. Quote Link to comment Share on other sites More sharing options...
garrycol Posted October 26, 2005 Author Share Posted October 26, 2005 I have use these products on external damage to radiators and they've lasted for years without trouble.I would try the putty's there good I carry laods of diffrant make ones when racing to use for emergency repairs. I fixed my disco 2 when she had a 4mm hole in a thermostat hosing with it so a pinprick hole should do a perminate fix fine. Thanks Jules -I considered the putty but that means getting at the matrix - too much hard work - I am lazy. Was hoping something poured into the radiator would be less taxing and work as well - any thoughts on these products. Cheers Quote Link to comment Share on other sites More sharing options...
jules Posted October 27, 2005 Share Posted October 27, 2005 Try it I wouldn't worry put it in and see if it works. Just clean the water bottle after Quote Link to comment Share on other sites More sharing options...
