tedsmart Posted August 28, 2007 Author Share Posted August 28, 2007 No not inside the snorkel.... I worked for a while in the racing car world and there is a pneumatic pipe called decabon http://www.lister.co.uk/ecommerce/response...sport&id=12 ask for Andy Berry. This is aluminum tube with black plastic casing and is hand maliable (you can bend it and it stays).This was run down the external surface of the snorkel, and tie wrapped in between it and the windscreen. This meant no holes in the roof! Very good neat as well! Ill have to make a plan! Quote Link to comment Share on other sites More sharing options...
Def V8 90 Posted August 27, 2011 Share Posted August 27, 2011 Sorry to resurrect a v old thread but..... I have some spots I would like to wire in to the 3-way (on-off-on) carling switch so it works like my fan on the 3-way switch next to it: on, off and with main beam... As my fans are switched on by a thermostat (a dual one - X-fan) I am struggling with the translation of the wiring to a relay spur off the headlights!!! Thanks for your help!! GG Quote Link to comment Share on other sites More sharing options...
