Corrode Finger Posted August 26, 2007 Share Posted August 26, 2007 Worryingly, jules looks quite at home in front of that ute!! Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted August 26, 2007 Author Share Posted August 26, 2007 Could always get a pig shotting ute and then put that on a rangie chassis Or this Ford XR8 . Has the V8 and the bull bar and spots already Shame about jules and mine ugly mugs in the pics though That's almost as disgusting as the pic Moglite posted ! And yes I am referring to the ute. Bill. Quote Link to comment Share on other sites More sharing options...
jules Posted August 26, 2007 Share Posted August 26, 2007 Worryingly, jules looks quite at home in front of that ute!! Quote Link to comment Share on other sites More sharing options...
Bush65 Posted August 26, 2007 Share Posted August 26, 2007 John, I am at 2 metres high with just over 500mm belly clearance and 110mm of rear axle uptravel.so the vertical dimension of the body chassis assembly is about the same .How do you manage to get in and out of the Bushie at that height ? Do your airbags expand when the coil springs reach the point of dislocating and then guide the spring back into position ? No, they are strut airbags on 14" swayaway racerunner coil overs. Can run 0 to 200 psi, to change the spring rate or height on the fly. I had some pics of mine but can't find them. The bushie is half stripped at the moment and the coil overs are not fitted. Here is a pic of a modified bushie with portals and the same airbags on different coil overs. From memory the coil overs in the pic are 16" (or maybe 18"). Quote Link to comment Share on other sites More sharing options...
Bush65 Posted August 26, 2007 Share Posted August 26, 2007 John, I am at 2 metres high with just over 500mm belly clearance and 110mm of rear axle uptravel.so the vertical dimension of the body chassis assembly is about the same .How do you manage to get in and out of the Bushie at that height ? ... There are side steps, but they are above chassis height. It is a bit over 1100 to the door sill. Hopefully that will come down some with the mods. Quote Link to comment Share on other sites More sharing options...
