oddballrovers Posted August 27, 2007 Share Posted August 27, 2007 Hia Folks Just stumbled over these Orbit-eye things,looks very cool, but does it work and does anybody know if it can be done on a series vehicle or has an idea on how to do it. Kind regards Ole. Quote Link to comment Share on other sites More sharing options...
sheeppimp Posted August 27, 2007 Share Posted August 27, 2007 whats one of them? do you have a link? Quote Link to comment Share on other sites More sharing options...
oddballrovers Posted August 28, 2007 Author Share Posted August 28, 2007 whats one of them? do you have a link? Link to the two I've found:http://www.alcanspring.com/orbit-eye.htm and http://deaverspring.com/BajaBushing.htm Hope It makes more sence with these links. Kind regards Ole. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 28, 2007 Share Posted August 28, 2007 I can think of more important things to spend £85 on, but if you were to, then I would suspect it is just a case of pressing the old out, and pressing the new in..... oh and the new set of springs you'll need unless you already have them Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 28, 2007 Share Posted August 28, 2007 TBH I think the springs are the thing that limits Series articulation - if you haven't got parabolics, they would be a better investment. Longer shocks would be the next thing, although most people do springs & ProComp shocks at the same time. With a totally non-special setup I can flex my parabolics flat / max out a 14" shock. I do have slightly extended shock mounts to accommodate but the springs are normal LWB HD paras. I just realised I haven't tried my Gon2far mounts or revolvers yet Quote Link to comment Share on other sites More sharing options...
RPR Posted August 28, 2007 Share Posted August 28, 2007 TBH I think the springs are the thing that limits Series articulation - if you haven't got parabolics, they would be a better investment. Longer shocks would be the next thing, although most people do springs & ProComp shocks at the same time.With a totally non-special setup I can flex my parabolics flat / max out a 14" shock. I do have slightly extended shock mounts to accommodate but the springs are normal LWB HD paras. I just realised I haven't tried my Gon2far mounts or revolvers yet I agree with the above. The other thing that I would add is that Series springs, standard or parabolic are short, therefore less flexy. Longer springs would also be another viable mod. I have RM parabolics, Revolver shackles, and long travel shocks. I get more travel than a Defender 90 with a 2"- 3" lift (retained springs) and offroad ride quality is about the same as said coiler. I use Land Rover rubber bushes. Quote Link to comment Share on other sites More sharing options...
oddballrovers Posted August 29, 2007 Author Share Posted August 29, 2007 Hi Folks I think Imust just sort off describe my setup, its a light LWT, TIC paras front and rear, Procomp chocks as per Gon2Far but not as solid, more race car like tovers out off 10x20mm tube.Home mad props out off agrieculturalstuff and some LR yokes. I can not run revolvers and I can not alter the spring mount to some pivoting type, ( MOT wiill not allow) so unles somebody has new ideas my last thing is to somehow do something to the longitudinal spring twist. So tell me where it is better to go and spend my 85£ so I get more travel. The problem is most pronounsed going up hill and some one have diged holes and cros axle comes in. since it is upwards there is not so much load on the springs to fully compres them.... result no contact with the ground. Ole. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 29, 2007 Share Posted August 29, 2007 If that's your setup, then yes, you probably are at the far end of leaf-sprung articulation, and they would most likely help you out here! Original reply was based on you haveing no major mods, but as you have......... Let us know how you get on mate Quote Link to comment Share on other sites More sharing options...
RobotMan Posted September 6, 2007 Share Posted September 6, 2007 They are similar to a Johnny Joint it seems. Johnny Joint Link I guess if there is a size available to fit into the spring eye then it would be quite an interesting and fairly straight forward option. Quote Link to comment Share on other sites More sharing options...
