Wire Colour on ignition
Can someone tell me the colour(s) wire I need to tap into to install a switch so that when the ignition ket is turned on my 110 the starter just turns but it never fires up? I did this on my 90 but can't remember what I tapped into.
Appreciate it could be a sensitive question so please PM if you want to.
Thanks
Gavin
you want the wire that runs to the stop solenoid, it's the thin white wire that dissapears off through the bulkhead. trace it back from the solenoid to be sure you've got the right one.
Thanks for the reply. I've traced the wire from the stop solenoid (a black one in my case) but it goes into a load of bundled/hidden wires and then off to the bulkhead. I had the instrument panel off and looked on the back of the ignition switch and I have the following wires
Thick brown
Thick White
small red/white
small orange/white
Should point out my 110 has the factory immobiliser thing around the barrel....
You cant do it, unless you have a very hefty relay. I dont know the exact max current but it must be over 50A
It would be in the White line.
Brown is a permanent (unfused) live
White is the switched (Unfused) live
red/white is the starter relay feed
white/orange is the accesory feed
surely better to interupt the starte or fuel pump, no?
I really don't mind what I do as long as I can stop either of the with the use of a hidden rocker switch. From memory when I did my 200tdi, I tapped into the white/blue on the back of the ignition switch but the 300tdi is different.
Has anyone done or can they supply some instructions. I don't want to fit a FIA battery isolator as what with the alarm, will get complicated.
 Share
