rekab69 Posted August 28, 2007 Share Posted August 28, 2007 Ahhhhhh!!!!!!!! Can't believe I did this....!! I've snapped off one of the pastic pipes banjo's which run from the injectors. Can I buy just one banjo? or do I need to buy the whole pipe assembley for all the injectors?? TDi 200 cheers Dave Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 28, 2007 Share Posted August 28, 2007 Is it the plastic pipe you've broken or the nipple bit of the banjo. If it's the pipe just put a new section of pipe if the latter then it's a new set Quote Link to comment Share on other sites More sharing options...
rekab69 Posted August 28, 2007 Author Share Posted August 28, 2007 Is it the plastic pipe you've broken or the nipple bit of the banjo. If it's the pipe just put a new section of pipe if the latter then it's a new set Hi Walfy, It's the banjo part in the end of the plastic pipe,where it attaches to the injector, what is the whole set up called, fuel return pipes...? Any idea who would have them or is it a main agent visit...? Would it be worth posting for it in the classifieds on here...?? cheers Dave Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 29, 2007 Share Posted August 29, 2007 I replaced mine on my 200TDI. I went to Bearmach in Maidstone. Gen only I think Paid about 20 quid I think . There are 2 types that fit. It's all down to where the pipe meets the FIP that determines it IIRC. HTH Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 29, 2007 Share Posted August 29, 2007 I have some off a 300TDi - are they the same? A little ring with two thin pipes pointing at approx 90deg to each other and made out of steel? Les. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 29, 2007 Share Posted August 29, 2007 Les I would assume that if the inj are different then the feed banjo's will be as well. I suppose it wouldn't hurt to measure them. The pipe between he banjo's is readily avail Quote Link to comment Share on other sites More sharing options...
