Alastair Posted August 30, 2007 Share Posted August 30, 2007 Hi, I'm trying to find out if there are differences in the tapper angle of the ball joint/trackrod end pins between the Series I, II,III and the Disovery models - these have different part numbers in the lists I've seen. I'd like to use LR trackrods and trackrod ends to make an uprated (low slop!) steering set-up for a 1930 Riley vintage racer. The Riley steering arms have a 3 degree (one side) tapper angle while the LR ball joint I found has a 5 degree tapper angle. Would anyone know whether any LR models (usiing the tubular trackrod) use a 3 degree pin and if so which one? Many thanks in advance, and sorry for the strange nature of this question. Alastair Bailey Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 30, 2007 Share Posted August 30, 2007 I believe the tapers are all the same. Series 2 uses a short stud, the early (replaceable) boot, is greaseable and the thread that goes into the track rod is not fully threaded. Series 3 uses a short stud , the later (non replaceable) boot, is non greaseable, and the stud that goes into the track rod is fully threaded. Series 2 and 3 ones are interchangeable so long as you use the correct track rod to match the track rod ends. Disco (etc) is per series three, but the stud is longer as the steering arm on the swivel is thicker than on a series. Disco ones can be used on a series 3 so long as you use packing washers under the nut otherwise you cant fully tighten it. Dont know about series ones however. HTH Jon Quote Link to comment Share on other sites More sharing options...
Alastair Posted September 10, 2007 Author Share Posted September 10, 2007 Dear John, Thankyou very much for your informative reply! Time to get on with the job. Alastair. Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 10, 2007 Share Posted September 10, 2007 It is my belief that ball joint tapers are expressed as inches per foot. Landrover ball joints are all 2.5" per foot. I can't be bothered to work out what 3degrees give per foot but they seem to go in half inch increments. Just for interest, Japanese ball joints use a proper ratio system, Landcruiser ball joints are a 1:10 taper. Quote Link to comment Share on other sites More sharing options...
biasbilt Posted September 10, 2007 Share Posted September 10, 2007 I don't know if it helps, but I think that some VW ball joints have a 6 degree taper (3 either side). If this useful, I can check with a friend who is into VWs and knows this sort of info. Toby Quote Link to comment Share on other sites More sharing options...
