LR90 Posted August 31, 2007 Share Posted August 31, 2007 OK, I'm still bother by my 90's temp gauge (which I now notice drops on RH bends!). So before I start swapping all sorts of bits out what are the recommendations for some form of temp probe to add to my limited toolkit so I can check the temp of block, rad headers, ... whatever and see if I really do have a problem. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 31, 2007 Share Posted August 31, 2007 Halfords for £17 Paul Wightman had one for his winch motors I use it on other items to check temperatures Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 31, 2007 Author Share Posted August 31, 2007 Well I like the simplicity and price, might give it a go. Cheers Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted September 1, 2007 Share Posted September 1, 2007 Maplin do a £15 multimeter with a thermocouple too... Quote Link to comment Share on other sites More sharing options...
LR90 Posted September 3, 2007 Author Share Posted September 3, 2007 Halfords for £17Paul Wightman had one for his winch motors I use it on other items to check temperatures Only seems to go to 70.0C and then just says HI Anyone tried that IR ones? Quote Link to comment Share on other sites More sharing options...
white90 Posted September 3, 2007 Share Posted September 3, 2007 really? Mine is mounted on a heat exchanger never seen over 60ish. best package it back up and return to Halfords as a faulty unit Quote Link to comment Share on other sites More sharing options...
LR90 Posted September 3, 2007 Author Share Posted September 3, 2007 I stuck on the thermostat housing. Seemed fine and I guess intended as an air temp gauge but even so you'd think it would be easier to just read out the temp that revert to HI once past 70.0C Quote Link to comment Share on other sites More sharing options...
Countax Posted September 9, 2007 Share Posted September 9, 2007 I stuck on the thermostat housing. Seemed fine and I guess intended as an air temp gauge but even so you'd think it would be easier to just read out the temp that revert to HI once past 70.0C Trev, I have used the IR type and can recommend them. They are not affected by the cooling air of the fan and you simply point the laser marker on the surface you wish to measure and then read the display. They are also a useful tool for locating problems such as missfire by pointing at the injector or exhaust area and seeing which one is lowest. All in all i would say its been a good investment and not that expensive. Nigel Quote Link to comment Share on other sites More sharing options...
