derodster Posted September 3, 2007 Share Posted September 3, 2007 Gm All, My indicator cancel thingy seems to be 90 degrees out ie if I turn the wheel to the 3 o'clock position that seems to be where the center is but then of course the front wheels are turned to the right. Is there something on the steering column i can adjust to re center it. I should say this comes after a "mechanic" took the wheel off in an effort to adjust the tracking !!!!! and no I wont be using him again...... any help appreciated ta deRod Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 3, 2007 Share Posted September 3, 2007 Steering wheel is probably mounted incorrectly. Steering wheel position is adjusted through the drag link. Quote Link to comment Share on other sites More sharing options...
yellow Posted September 3, 2007 Share Posted September 3, 2007 The cancelling tab is located under the steering wheel and the cowel. put the wheels in a straight position, take the steering wheel off, and the cowel, and reset the little tab. It is that easy... (...after you have expressed yourself in perfectly politically uncorrect anglo-saxon to get the steering wheel off) Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 3, 2007 Share Posted September 3, 2007 When removing the steering wheel if you value your nose don't forget to loosen but not remove the wheel securing nut Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 3, 2007 Share Posted September 3, 2007 The rotating collar that the steering wheel tabs fit into has an arrow or mark on one side of it, ensure this goes to the left so that you get proper cancelling in both directions. HTH Mo Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 3, 2007 Share Posted September 3, 2007 When removing the steering wheel if you value your nose don't forget to loosen but not remove the wheel securing nut or wear a crash helmet Quote Link to comment Share on other sites More sharing options...
derodster Posted September 3, 2007 Author Share Posted September 3, 2007 Ok on all that and self harm points taken. thanks to you all for your time and clear explanation adios for now deRod Quote Link to comment Share on other sites More sharing options...
