pinny Posted September 3, 2007 Share Posted September 3, 2007 after 2 hours of sweat bit of blood and nearly tears finally got bead to seat trying to put a 205 on a modulad found a little easier way by putting a ratchet strap around tyre which pushed tyre onto bead plenty of wax paste and eventually got a seal looking at making a bead seating tank from either a lorry air tank has any one made one of these and what did you use chris Quote Link to comment Share on other sites More sharing options...
white90 Posted September 3, 2007 Share Posted September 3, 2007 On Saturday with 25mins before the end of the event Mikes 90 rolled a Simex off the bead we borrowed a T max compressor from Honiton hobbit we used a recovery strop around the tread then a stick to tighten the strop the compressor blew the tyre up and onto the rim. unfortunatley we didn't have a High lift either so we used a strop around a near by tree and winched the car into the air to effect the above Quote Link to comment Share on other sites More sharing options...
pinny Posted September 3, 2007 Author Share Posted September 3, 2007 On Saturday with 25mins before the end of the event Mikes 90 rolled a Simex off the beadwe borrowed a T max compressor from Honiton hobbit we used a recovery strop around the tread then a stick to tighten the strop the compressor blew the tyre up and onto the rim. unfortunatley we didn't have a High lift either so we used a strop around a near by tree and winched the car into the air to effect the above im looking at making one of these got valves etc just need a tank ebay no 300000122340 what do you think even looked at a gas cylinder but had a nasty experience striking an arc on one a few years ago Quote Link to comment Share on other sites More sharing options...
Lewis Posted September 4, 2007 Share Posted September 4, 2007 On Saturday with 25mins before the end of the event Mikes 90 rolled a Simex off the beadwe borrowed a T max compressor from Honiton hobbit we used a recovery strop around the tread then a stick to tighten the strop the compressor blew the tyre up and onto the rim. unfortunatley we didn't have a High lift either so we used a strop around a near by tree and winched the car into the air to effect the above Why didnt you just use a winch around the tyre, rather than faffing about with strops? Quote Link to comment Share on other sites More sharing options...
white90 Posted September 4, 2007 Share Posted September 4, 2007 Lewis did you miss the bit that say s we used the winch to lift the car in the air? hence the As you say "faffing" about with strops Quote Link to comment Share on other sites More sharing options...
andyb Posted September 4, 2007 Share Posted September 4, 2007 Remove the valve core, this allows you to get more air in there quicker and so will seat the bead. Once the tyre is on the bead you can put the core back in a blow the tyre up as normal. I had to do four 33inch tyres at work that way Quote Link to comment Share on other sites More sharing options...
Lewis Posted September 5, 2007 Share Posted September 5, 2007 Lewis did you miss the bit that say s we used the winch to lift the car in the air?hence the As you say "faffing" about with strops You mean you only had the use of one winch? Quote Link to comment Share on other sites More sharing options...
Gromit Posted September 5, 2007 Share Posted September 5, 2007 What about the lighter fluid trick? Quote Link to comment Share on other sites More sharing options...
white90 Posted September 5, 2007 Share Posted September 5, 2007 You mean you only had the use of one winch? yes as this was Mike car that runs in standard class 1 winch no lockers Quote Link to comment Share on other sites More sharing options...
Paul2A Posted September 5, 2007 Share Posted September 5, 2007 What about the lighter fluid trick? Easy start works much better! but start with small doses Quote Link to comment Share on other sites More sharing options...
Revor Posted September 5, 2007 Share Posted September 5, 2007 Easy start works much better! but start with small doses A very small dose! And take out the valve core! It's amazing how fast those things fly! Quote Link to comment Share on other sites More sharing options...
