David Sparkes Posted September 4, 2007 Share Posted September 4, 2007 A blatant second post, the original is in Classifieds, placed there just in case someone had such a pump for sale. It seems not, so I've reworded the topic, and will just look for what advice is available. The High Pressure Diesel Fuel Injection pump on a 12J (2.5) engine is leaking fuel at the rate of about 1 drop per second while the engine is running. I cannot see exactly where it's leaking from, the closest I can get to is halfway along the body, on the side closest to the engine block. I've no prior experience with these devices, so it might be a simple failure, with a simple repair, or not. I'm not sure whether to try and pick up a 'known' good one from somewhere (any suggestions?), or go to someone like 'addocks to see what they can offer, or have 'my' pump overhauled. Officially it hasn't done an inter-galactic mileage so shouldn't be worn out, but the evidence is that the PO ran it like this for some time. He didn't do many miles, so any repair cost wasn't justified by the fuel saving. Mind you, he probably didn't realise that washing the front propshaft UJ in diesel is a good way of knackering it. Anyway, suggestions on the best way forward will be gratefully received. Cheers. In case it doesn't say in my profile, I'm in Derbyshire, about 5 miles from Paddocks, as it happens. I also intend going to the Peterborough show, in another vehicle, on Sat 9th Sept. Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 4, 2007 Share Posted September 4, 2007 i'd be tempted to see wot s/hand ones paddocks have, the only thing i've ever done is change a front seal but that isn't really takin the pump apart. or take it apart and see wot u find Quote Link to comment Share on other sites More sharing options...
Paul2A Posted September 4, 2007 Share Posted September 4, 2007 Give it a good wash down with brake cleaner or similar and find an old rear view mirror to help you see the leak, may well be an easy fix! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 4, 2007 Share Posted September 4, 2007 I have one of these pumps down the shed David, so I got the spanners out! There's quite a few placed on the engine block side of the pump that could leak. Most possible leak areas are sealed with O-rings, or sealing washers. There is a gasket however, that I suppose is the most likely to leak, although I have experienced the injector pipe connections leaking in the past - compression washers either side of the fittings and I only had to tighten the bolt to cure the problem. Some pictures that might help anyway:- The side of the pump closest to the engine block. O-ring seal. O-ring and alloy/rubber compression washer. This (whatever it is) has a gasket where it contacts the main body of the pump, a copper compression washer on the smaller nut, and an O-ring/compression washer on the larger one (banjo bolt). It would be a lot easier if you could devise some way of seeing up/down the side of the injector pump with either a mirror, camera phone, or camera (if you have a cheapo one like me) Les. Quote Link to comment Share on other sites More sharing options...
TEMPL4R Posted September 4, 2007 Share Posted September 4, 2007 This (whatever it is) That is the advance Les, you can see where it joins the cam ring. it moves and advances the point of injection when the engine speeds up. A bit like the advance on a distributor. Sometimes there is a big disc, that is a damper. Chris Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 4, 2007 Share Posted September 4, 2007 That is the advance Les, you can see where it joins the cam ring. it moves and advances the point of injection when the engine speeds up. A bit like the advance on a distributor. Sometimes there is a big disc, that is a damper.Chris You don't know how to strip/rebuild one of these things do you Chris - now that's impressive. Bit of a dark art in my opinion. Les. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted September 4, 2007 Author Share Posted September 4, 2007 I see Les, that you will go to 'any' lengths to get me to post pictures on this blessed site!! Seriously, thanks for your efforts with the camera and spanners. I think I'm fully booked this weekend, and the 38A needs some TLC, so it may be sometime before I can rerun the engine. I've just had a quick look, and it's only surface dirt, which might actually help me spot the origin, if I happen to be looking in almost the right place soon after starting the engine. If it doesn't, I'll clean then dry the pump, and try again. Thanks again. Quote Link to comment Share on other sites More sharing options...
