Dave Gill Posted September 4, 2007 Share Posted September 4, 2007 I have an early 110 with a tired 2.5NAD engine, which I'd like to upgrade. Is there any good information on the net about fitting a 300 Tdi engine into a 110, retaining the LT77 and Lt230 transmission? Any pointers would be most welcome. Quote Link to comment Share on other sites More sharing options...
Daan Posted September 4, 2007 Share Posted September 4, 2007 I have an early 110 with a tired 2.5NAD engine, which I'd like to upgrade.Is there any good information on the net about fitting a 300 Tdi engine into a 110, retaining the LT77 and Lt230 transmission? Any pointers would be most welcome. Take the bellhousing and dowels of your NAD engine. It fits straight on the box, then start worrying about the enginemounts. daan Quote Link to comment Share on other sites More sharing options...
Dave Gill Posted September 4, 2007 Author Share Posted September 4, 2007 Do I retain the 300 Tdi clutch and flywheel, or use the parts from the NAD? Quote Link to comment Share on other sites More sharing options...
Daan Posted September 4, 2007 Share Posted September 4, 2007 Do I retain the 300 Tdi clutch and flywheel, or use the parts from the NAD? all 300 Quote Link to comment Share on other sites More sharing options...
Dave Gill Posted September 4, 2007 Author Share Posted September 4, 2007 Thanks my friend ! Quote Link to comment Share on other sites More sharing options...
Diff Posted September 4, 2007 Share Posted September 4, 2007 Dave, bear in mind that if your 110 has its original transfer box, it will have a 1.66 ratio high range due to the low power of the original engine. This means you won't get the best out of your 300tdi unless you are going to fit some very tall tyres too. The 1.66 ratio transfer box is will mean the 300tdi will be really revving hard on fast main roads and motorways. If you are staying with standard dia tyres, you should fit a standard defender 1.4 high range transferbox. Regards, Diff Quote Link to comment Share on other sites More sharing options...
