western Posted September 4, 2007 Share Posted September 4, 2007 OK, Guys & Girls My 110's front diff pinion bearing has far to much horizontal & vertical play, can it be changed without removing the diff assembly from the axle case ? I know the front prop & pinion flange will have to be removed. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 4, 2007 Share Posted September 4, 2007 OK, Guys & Girls My 110's front diff pinion bearing has far to much horizontal & vertical play, can it be changed without removing the diff assembly from the axle case ? I know the front prop & pinion flange will have to be removed. Maybe, if you can figure out how to pull the race. But it will be hard to properly setup the bearing preload. Also, it could be the inner bearing. When either bearing goes, you get slack. Quote Link to comment Share on other sites More sharing options...
western Posted September 4, 2007 Author Share Posted September 4, 2007 Hmmm, perhaps I'm looking at a replacement diff assembly then, not overly worried about that, the existing one has seen excess of 390,000 miles of road & gently off road use. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 4, 2007 Share Posted September 4, 2007 the existing one has seen excess of 390,000 miles of road & gently off road use. Is this in a triggers broom kind of way? Wow! I would have suggested having a go at rebuilding the diff as its not particularly hard to do, but in this case I wont! Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 4, 2007 Share Posted September 4, 2007 I agree, with that mileage, the ring and pinion and all bearings should be changed. Quote Link to comment Share on other sites More sharing options...
western Posted September 4, 2007 Author Share Posted September 4, 2007 Is this in a triggers broom kind of way? Wow! I would have suggested having a go at rebuilding the diff as its not particularly hard to do, but in this case I wont! Nope, it's the diff the 110 was built with, rear axle is the same too, they're not mega noisy when running either & have plenty of good quailty EP90 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 5, 2007 Share Posted September 5, 2007 The bearings come out internally Ralph and the pinion shaft is in the way, so diff assembly out I'm afarid. Might as well do all 4 while you are in there, then another 300 - odd thou before you need to touch it again. Les. Quote Link to comment Share on other sites More sharing options...
western Posted September 5, 2007 Author Share Posted September 5, 2007 Cheers Les, it'll have to survive a few more weeks until I've a free weekend to sort it out. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 8, 2007 Share Posted September 8, 2007 .....then another 300 - odd thou before you need to touch it again. Maybe, but if it were me I wouldn't run an R&P with 300k on it.... when you have it out and the chance to replace it. Quote Link to comment Share on other sites More sharing options...
