Roel J Posted September 6, 2007 Share Posted September 6, 2007 Hello, I want to fit an OMP 350 mm Velocita steering wheel. Steering column is 14 mm thick in outer dia. and has 36 splines. Comes of an 1985 90 HT LHD Diesel. Can anyone please tell me which is the CORRECT adapter for that steering column and the OMP? In Belgium they ALL say it wil fit, and I must pay in advance, which I don't trust. Cheers mates!! Roel Janssens Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 6, 2007 Share Posted September 6, 2007 afaik the 1985-1993 and 1998> use the same boss only the 94-98 300tdi models had a different boss Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted September 6, 2007 Share Posted September 6, 2007 The later model 300Tdi/Td5 (but not CSW) have 48-splines. The Bearmach part number for the 48-spline boss/adaptor you DON'T want is BA3201 if that helps avoid any mistakes. Bosses for MOMO fits OMP too. Got the Velocita myself, but went for the 380mm version. Kev Quote Link to comment Share on other sites More sharing options...
Litch Posted September 6, 2007 Share Posted September 6, 2007 As long as your wheel is the aftermarket industry standard '6-hole' pattern then practically any adapter will fit, you just need to get the one for your column (take off your existing wheel and count the splines to be sure). The one that won't fit (32 or 48 spline) is the Mountney 'classic' range boss as the wheel mounting is differnt however the Mountney '6-hole' pattern boss will probably take your wheel, you just need the correct one for your column. Speak to the Mountney helpdesk, they don't sell to the public but they will advise you and tell you what part to order from your local supplier, most suppliers just don't have the knowledge. Quote Link to comment Share on other sites More sharing options...
Roel J Posted September 7, 2007 Author Share Posted September 7, 2007 @ Kev, Did you bought the Bearmach MOMO adapter boss and fitted an OMP steering wheel? In that case, I am most happy What is the diameter of the MOMO wheels that are currently shown on the Defender Acc. page at Bearmach? Anyone? Thanks already Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted September 8, 2007 Share Posted September 8, 2007 QT Services sell wheels and adaptors, got me an adaptor for the 110 and bought a wheel (MOMO) from Eblag. Quote Link to comment Share on other sites More sharing options...
