need4speed Posted September 6, 2007 Share Posted September 6, 2007 When buying axles/diffs for my defender project, does it make a big difference if they utilise 3 or 4 bolt prop-shaft flanges? Is the 3 bolt design weak? Quote Link to comment Share on other sites More sharing options...
nas90 Posted September 6, 2007 Share Posted September 6, 2007 When buying axles/diffs for my defender project, does it make a big difference if they utilise 3 or 4 bolt prop-shaft flanges? Is the 3 bolt design weak? Did LR use 3 bolt flanges on props? Quote Link to comment Share on other sites More sharing options...
Porny Posted September 6, 2007 Share Posted September 6, 2007 Did LR use 3 bolt flanges on props? Only on 300Tdi Discos... they have a rubber doughnut assembley that's supposed to reduce driveline noise/shunts.. Personnally I wouldn't bother with it... stick to the normal 4 bolt flange assembley.... plus to run a 3 bolt on a Defender you'd need a custom rear prop shaft. Ian Quote Link to comment Share on other sites More sharing options...
need4speed Posted September 6, 2007 Author Share Posted September 6, 2007 Hey Ian! I take it the axles im buying off you have 4-bolt flanges then!!!! Phil Quote Link to comment Share on other sites More sharing options...
Porny Posted September 6, 2007 Share Posted September 6, 2007 Hey Ian! I take it the axles im buying off you then have 4-bolt flanges then!!!! Phil Yep Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 7, 2007 Share Posted September 7, 2007 I'd count them before parting with my cash if I were you Les Quote Link to comment Share on other sites More sharing options...
