tomster Posted September 6, 2007 Share Posted September 6, 2007 Hi, I´m new to this board and i have a actual question: I´m in the process to add a 2nd alternator to my 4.0 TJ. The original alt is a 120A unit and the 2nd one is a 150A Bosch out of a Mercedes Sprinter. The plan is to run both alts on one single Optima yellow top 75Ah. Since the 150A alt has no regulator onboard, i think about to add a Sterling power digital regulator. What do you guys think about this plan? Have you any sugestion? Any expirience with Sterling regulators? How you conected the 2nd Alternator ? THANX TOM Quote Link to comment Share on other sites More sharing options...
66gaza Posted September 7, 2007 Share Posted September 7, 2007 Hi, I´m new to this board and i have a actual question:I´m in the process to add a 2nd alternator to my 4.0 TJ. The original alt is a 120A unit and the 2nd one is a 150A Bosch out of a Mercedes Sprinter. The plan is to run both alts on one single Optima yellow top 75Ah. Since the 150A alt has no regulator onboard, i think about to add a Sterling power digital regulator. What do you guys think about this plan? Have you any sugestion? Any expirience with Sterling regulators? How you conected the 2nd Alternator ? THANX TOM I have 2 alternators but 2 battery banks, most people run 1 alternator even with 2 battery banks. I would suggest 1 BIG alternator if you only need 1 battery and 75AH isn't going to store the potential of 2 alternators very well. I am only guessing here but I think you will have some problems feeding 2 alternators into 1 battery. Outputs fighting each other. Why not just put a 200A on enstead probably cheaper aswell. I am only guessing here so I wont feel bad if you say OH YES YOU CAN. Gaza Quote Link to comment Share on other sites More sharing options...
