nobber Posted September 8, 2007 Share Posted September 8, 2007 on a td19j? mine has split. now , ive got to thinking , ive got some oil cooler pipes from a disco gearbox oil cooler , they are made from metal rather than rubber. i can pull a 90 bend in one to feed it down to the back of the block and in effect replace the rubber pipe with a metal one. i will obviousley have to join it to the block and breather but i can use rubber couplings and hose clips to do this. now , what kind of pressure can i expect to be running through this pipe? is it a breather pipe to vent the block or an oil return pipe? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 8, 2007 Share Posted September 8, 2007 It's just a breather pipe - to allow air pressure to equalise in the engine and then eventually vent into the air filter pipe. As long as the pipe isn't tiny I don't see why it wouldn't work. Les. Quote Link to comment Share on other sites More sharing options...
nobber Posted September 8, 2007 Author Share Posted September 8, 2007 nice one , thank you Les. Quote Link to comment Share on other sites More sharing options...
