KevinNY Posted September 8, 2007 Share Posted September 8, 2007 There is a black plastic cover with 3 wires over the fuel shut off solenoid on the rear of the fuel distributiion pump on my engine, is this an imobilizer? If so, how do I get rid of it? Is it simply cut it open, remove circuit board and go back to 1 wire to the solenoid? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 9, 2007 Share Posted September 9, 2007 I commented on this where you posted it on LRUK Kevin. Are those security bolts holding the box to the pump? If you can remove the bolts and identify which (if any) wires go to the fuel switch, then you could possibly remove the box and just wire straight to the the switch via your ignition as normal. There's a possibility that the switch may not be 12v though. If you run an earth wire to the pump body, and then briefly touch the live wire to the switch it should click if it operates ok. It would easiest if you could find out from someone who knows exactly what the box is - you could possibly bypass it without damaging anything. Les. Quote Link to comment Share on other sites More sharing options...
Paul2A Posted September 9, 2007 Share Posted September 9, 2007 Usually there are two security screws, remove these the box should pull away leaving the one wire and a horse shoe shaped bracket, remove these and put your standard wire to the solenoid as usual If the screws are the type that break off try a small shape chisel to tap them round or 'dig' a little of the plastic away to get a set of grips to it. Quote Link to comment Share on other sites More sharing options...
KevinNY Posted September 9, 2007 Author Share Posted September 9, 2007 Thank you, thats the best description I've received yet. Quote Link to comment Share on other sites More sharing options...
KevinNY Posted September 9, 2007 Author Share Posted September 9, 2007 Done, thanks again. Quote Link to comment Share on other sites More sharing options...
crusherman Posted March 14, 2011 Share Posted March 14, 2011 i know this is an old topic but do you know what the 2 wires at the front of the pump are for ? thanks jim Quote Link to comment Share on other sites More sharing options...
