BigSi110 Posted September 9, 2007 Share Posted September 9, 2007 Just checking gearbox levels as well today. I've managed to get ATF all down my arm after loosening the main gearbox filler plug. That's got to be OK then. The transfer box plug just won't shift. It's currently sitting with WD40 sprayed all over it. Standard ratchet handle; lots of effort; nil movement. I don't have a breaker bar - can't think that'll do the 'box any good. Levels were supposedly checked and topped-up a few months ago. PLEASE, any suggestions? Quote Link to comment Share on other sites More sharing options...
Guest otchie1 Posted September 9, 2007 Share Posted September 9, 2007 3in1 penetrating oil on the threads for about an hour and then the usual forwards/backwards routine. I think I used a breaker bar on mine..it wasn't gorilla tight but it need more than I wanted to put through a standard ratchet. Quote Link to comment Share on other sites More sharing options...
simonb Posted September 10, 2007 Share Posted September 10, 2007 3in1 penetrating oil on the threads for about an hour and then the usual forwards/backwards routine. I think I used a breaker bar on mine..it wasn't gorilla tight but it need more than I wanted to put through a standard ratchet. Breaker bar is only about 15 squid from Halfrauds. The hole in the casing is a taper thread, don't over tighten just "nip" it up. Quote Link to comment Share on other sites More sharing options...
