Taff Posted September 10, 2007 Share Posted September 10, 2007 Hello All, Can anybody help, I have a 52 plate disco with a on/off switch for a clutch. I am going to change it, but I have been told that it has a twin mass flywheel & therefore to do the job correctly should look at changing the secondary Mass!!!! (don't understand this mass business) as well as the clutch???? is this correct & if so how much should the parts be? (ball park figures) Cheers for any help, Taff. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 10, 2007 Share Posted September 10, 2007 AFAIK the flywheel is a one piece thing I don't think it comes to bits (well it does in early Td5's but that is not a reversible process ) so as far as I know it is just a straightforward swap like any other. I would make an assessment when you have the clutch out to look at it, rather than assume it does or doesn't need changing without having seen it. Quote Link to comment Share on other sites More sharing options...
