gav- Posted September 10, 2007 Share Posted September 10, 2007 how do u know how a diesel injector has failed. i have been told that when you take off the return pipe from the injector there should only be a weap of fuel coming from the top throughout the rev range. is this true? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted September 10, 2007 Share Posted September 10, 2007 If it's a problem, take the injectors to a diesel injection specialist, they can check the spray pattern of each injector and then ultrasonically clean and service it, if needed. Don't be tempted to try looking at the spray pattern yourself, the pressure is high enough to force fuel through your skin etc, which would be nasty. Quote Link to comment Share on other sites More sharing options...
gav- Posted September 10, 2007 Author Share Posted September 10, 2007 yeah thats what i have found out. max pump pressure is 1350psi. very dangerous Quote Link to comment Share on other sites More sharing options...
western Posted September 10, 2007 Share Posted September 10, 2007 Only way to tell if a injector is servicable is to have it checked for spray pattern/pressure & correct operation by a diesel specialist. Quote Link to comment Share on other sites More sharing options...
