dirtydiesel Posted September 20, 2008 Share Posted September 20, 2008 Why even have bushings at the axle? Quote Link to comment Share on other sites More sharing options...
nicks90 Posted September 22, 2008 Share Posted September 22, 2008 cos its cheaper and easier to replace a set of bushes once a year than potentially suffer stress fractures from having solid mounting points. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 22, 2008 Author Share Posted September 22, 2008 Why even have bushings at the axle? It's an ongoing experiment - Rover use bushes in their arms on coilers, so we did the same - to be fair when the bushes were in good nick it worked fine, hopefully the polybushes will last a bit longer. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted September 26, 2008 Share Posted September 26, 2008 cos its cheaper and easier to replace a set of bushes once a year than potentially suffer stress fractures from having solid mounting points. Given that they are bushed at the chassis end and properly fabbed at the axle end they shouldn't suffer any cracks. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 26, 2008 Share Posted September 26, 2008 I'd vote for keeping bushes Dan - you know the "less than perfect" road surfaces John drives on - I would have thought that having the additional rubberware in the assembly would give a longer lifespan as loads are shared, its an interesting long term test though superpro if/when the polys die John? Im dead impressed with the beasting they seem to put up with what size heims are they, there might be some spares in stores? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 26, 2008 Author Share Posted September 26, 2008 "Additional rubberware" eh? I'll see how the polybushes go, at least they'll be easier to change if they do die. I found my spare heims so all's well there thanks. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 26, 2008 Share Posted September 26, 2008 Fridge, i do like your 109 Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted September 26, 2008 Share Posted September 26, 2008 Most of the yank ones use hiems at the axle ends, almost none of them use bushes. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 26, 2008 Author Share Posted September 26, 2008 Most of the yank ones use hiems at the axle ends, almost none of them use bushes. I think heims at the axle end would encourage it to skew sideways rather than react against the load though, with the heim on the shackle as well it would be able to twist the assembly off to the left or right rather than staying in a straight line and taking the load. That's why I have a box of spare heims, originally we planned to do it with heims all round, then I thought it might make it kinda floppy Quote Link to comment Share on other sites More sharing options...
AV8R Posted April 8, 2018 Share Posted April 8, 2018 Quoting Fridge Freezer from the Leaf makes thread, about an update on this subject and trying to remain on topic: Well for the last 5 years it's hardly been driven so can't really comment... but I reckon the front binds up a bit but the rear works a treat due to being the other way round and having much longer links (very close to the length of a leaf). I'm still mulling solutions for the front but just need to get the damn truck up & running again before starting more projects! End quote. What about bringing the torque arm for the front axle to the front ? Tie it to a new crossmember right behind the bumper. Too many tie rods in the way ? Quote Link to comment Share on other sites More sharing options...
Daan Posted April 8, 2018 Share Posted April 8, 2018 There are basically 2 options: a Ladder bar (like fridgefreezer) or a tractionbar (like Soren has on his series 1 landrover). From a geometry point of view, a traction bar is a better solution, as a traction bar will fight the axle movement, as it forces the axle to rotate around an arc, which is not its natural movement. This is quite well explained here (albeit on toyot landcruiser): http://www.deckersonline.com/fj40_traction_bar Daan Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 8, 2018 Share Posted April 8, 2018 We just used an old radius arm and a johnny joint. Cheap, quick and easy. Works great. 1 Quote Link to comment Share on other sites More sharing options...
Codmaster Posted July 21, 2020 Share Posted July 21, 2020 Red 90 - this looks a great idea, did you do front axle as well? any more pics of how the shackle was attached to cross member ? Quote Link to comment Share on other sites More sharing options...
