TD loom
JST
 Share
i have a TD Def with no engine in it.
i have the original loom fitted with one part of the TD engine loom plug. the other part of the plug left with the engine!
What i would like to know is which wire does what that goes into the the engine loom plug/vehicle loom side.
i know that i will have
+12V perm
water temp - (green??)
oil pressure
Alt
starter - white/red trace (IIRC)
is that it? and does anyone know the colours of these?
After I got my 90 I asked the previous owner Weeble about a few wires I needed to trace/sort out and his answer was it's the red 1. Any work he did he just usedthe cable that he had avail. It's just that the only colour was red :(
+12V perm
oil pressure
Alt
from Defender workshop manual wiring section, 2.5 diesel harness colours [same for n/a & TD & 200Tdi]
Brown (N) starter soleniod/multi junction within main harness
White/Red (WR) starter soleniod/start relay behind fusebox
White/Brown (WN) oil pressure transmitter/ warning light on dash
White (W) fuel shut off soleniod/ignition switch
Brown/Yellow (NY) alternator/battery charge/ignition warning light
Green/Blue (GU) water temperature transmitter/gauge
hope that helps
:D
 Share
