bernie Posted September 12, 2007 Share Posted September 12, 2007 I have a 1989 Range rover with a 5 speed manuel gearbox, it has high and low ratio only, no Difflock, I require a new front prop, I have been told i need a viscous prop but the prop that was on the vehicle is a standard style prop, Have i been misinformed? Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 12, 2007 Share Posted September 12, 2007 I have a 1989 Range rover with a 5 speed manuel gearbox, it has high and low ratio only, no Difflock, I require a new front prop, I have been told i need a viscous prop but the prop that was on the vehicle is a standard style prop, Have i been misinformed? Yes I believe you have been misinformed, no such thing as a viscous prop in my knowledge. What you do need is a front prop for a Range Rover with a LT77 and borg warner transfer box, which is a different length to other setups with a LT230 transfer box. Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted September 12, 2007 Share Posted September 12, 2007 Just been through this, here's what I learned. Front props come in 2 lengths, one for LT230 vehicles, one for BW (viscous coupling, no diff lock) vehicles, the BW one is 2" longer IIRC. Furthermore, the BW ones come in 2 thicknesses, standard for non-cat equipped vehicles, and thin for cat equipped. The thin one is more expensive. Of course, you can use a cat prop shaft on non cat vehicle. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 12, 2007 Share Posted September 12, 2007 Just been through this, here's what I learned.Front props come in 2 lengths, one for LT230 vehicles, one for BW (viscous coupling, no diff lock) vehicles, the BW one is 2" longer IIRC. Furthermore, the BW ones come in 2 thicknesses, standard for non-cat equipped vehicles, and thin for cat equipped. The thin one is more expensive. Of course, you can use a cat prop shaft on non cat vehicle. The cat front type is a solid bar rather than tube, I guess about 1" diameter. Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted September 13, 2007 Share Posted September 13, 2007 If memory serves, a 90 rear is a straight swap for the non-cat bw front, but check first to make sure. Quote Link to comment Share on other sites More sharing options...
