bernie Posted September 16, 2007 Share Posted September 16, 2007 I want to lift my range rover, has anyone used the 2 inch spacers that you can buy on e-flog!!! iam not to worried about the extra articulation as i dont do loads off road, but i do wish the vehicle to be higher, has anyone used these and are they worth it, Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted September 17, 2007 Share Posted September 17, 2007 I want to lift my range rover, has anyone used the 2 inch spacers that you can buy on e-flog!!! iam not to worried about the extra articulation as i dont do loads off road, but i do wish the vehicle to be higher, has anyone used these and are they worth it, The only ones I have seen on Fleabay are the type that are a solid lump that fits between the axle and the spring seat. This works perfectly on the rear but on the front it closes the shock up by 2" so it will top out and damage the shock before the axle hits the bumpstop. The ones I sell allow the front shock to pass through the middle and fasten to its original location. Whilst this means you need to fit longer shock ( or at least should do ) it does mean that you don't knacker your shocks or have to pack your existing bumpstop by so much you lose all upward travel. Hope that helps Any questions PM / email / 01938.850382 and I can explain better what I am wittering on about! David Quote Link to comment Share on other sites More sharing options...
