ibexman Posted September 17, 2007 Share Posted September 17, 2007 As above????? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 17, 2007 Share Posted September 17, 2007 I had a normal rivetter-style one and it's OK but M8's are a bit of a fiddle. Andy's long-armed one is far nicer IMHO. Also, good quality rivnuts with a large flange make a difference, the cheap ones with a very thin lip around the top can pull through a panel before you get a decent pull on them, ask me how I know Avoid: These are better: Quote Link to comment Share on other sites More sharing options...
smo Posted September 17, 2007 Share Posted September 17, 2007 The ones with small lips are thin sheet rivnuts - for thin sheets The others are standard flanged rivnuts. I've got a Masterfix MFX-480QI rivnut tool, (about £90!) its excellent and makes it reasonably easy to put them in, so far i've used about 100 M6 steel rivnuts on the D-Lander! Quote Link to comment Share on other sites More sharing options...
alan kemp Posted September 17, 2007 Share Posted September 17, 2007 I bought some 4 mm and 6 mm to lift the roof up on my waggon. 3 mm ally onto 2 mm alley, pop rivets would never have done the job. I wanted hock bolts which are similar to the pictures you show, I enede up with what the professional body work guys use for artics etc, the air/hydro tool was over 300 sqid, once they are in they will never move, super strong. Quote Link to comment Share on other sites More sharing options...
biasbilt Posted September 17, 2007 Share Posted September 17, 2007 If you've only a few to put in and don't want the expense of buying a tol just for one job, just use a peice of steel bar, say 25 x 3mm with the appropriate size hole in it. Use it to hold the rivnut in place while you do about 3 turns on a bolt to pull the lower section up. We use a 3/8" butterfly impact wrench, or a ratchet and socket, when we can't get access to get the proper tools onto the job. Toby Quote Link to comment Share on other sites More sharing options...
swanny Posted September 17, 2007 Share Posted September 17, 2007 http://www.x-eng.co.uk/rivnut.asp hope this helps swanny Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 18, 2007 Share Posted September 18, 2007 The ones with small lips are thin sheet rivnuts - for thin sheets The others are standard flanged rivnuts.I've got a Masterfix MFX-480QI rivnut tool, (about £90!) its excellent and makes it reasonably easy to put them in, so far i've used about 100 M6 steel rivnuts on the D-Lander! I have something similar, the only problem I found with it is the difficulty of using the thing in confined spaces due to the length of the handles. Quote Link to comment Share on other sites More sharing options...
simonr Posted October 3, 2007 Share Posted October 3, 2007 I too have the same which comes with M5,6,8,10 dies. As per the above, it is hard to use in confined spaces and hence I find I use my diy riv-nut tool surprisingly often! Si Quote Link to comment Share on other sites More sharing options...
Steve H Posted October 4, 2007 Share Posted October 4, 2007 I've got one of these ones Eclipse Spiralux As the first reply said, they're a bit of a grunt with 8mm inserts, you wouldn't want to be doing too many but OK with the others sizes (4,5,6 & 8mm all included in the kit) Quite a bit cheaper than the Masterfix tool if you've not too many to do. Steve. Quote Link to comment Share on other sites More sharing options...
