Jon White Posted September 19, 2007 Share Posted September 19, 2007 Anyone got any bright ideas where I can source a couple of Fujitsu FBR562ND12-W relays from?? Rs dont do them, farnell dont do them..........they seem to be pretty specialist! Ideally I'd also like to source a V23076-A3001-C132 relay, but Rs stock V23076-A1001-C133 which would do so is less of a problem. Landrover relevance?? I'm replacing the faulty relays in the window lift Ecu on my rangie as its got to be cheaper to replace a couple of dodgy relays than buy a whole new ECU! Cheers Jon Quote Link to comment Share on other sites More sharing options...
simonr Posted September 19, 2007 Share Posted September 19, 2007 Jon, If they are only window lift drivers, does it matter that much exactly what part it is? If so, talk to Willow Technology - ask to talk to their relay specialist, whose name escapes me at the mo and say I suggested you talk to him. I've never met anyone so enthused with relays! He insisted on showing me his relay collection????!!!! http://www.willow.co.uk/ They would be my first call! Si Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 20, 2007 Author Share Posted September 20, 2007 Thanks Si, they are only window lift drivers, but obviously the pin out needs to be correct to fit the PCB, but they're unusual in that there are effectively 2 separate change over relays in one package. However a quick look at willow's wedsite shows something that may be suitable. I'll have a look at comparing the data sheets. Do you know if willow will deal with Joe Public wanting to order small quantities? This is the problem ive found with most of the large suppliers in this country - not interested unless you want to order thousands of them! Cheers Jon Quote Link to comment Share on other sites More sharing options...
simonr Posted September 20, 2007 Share Posted September 20, 2007 Thanks Si,they are only window lift drivers, but obviously the pin out needs to be correct to fit the PCB, but they're unusual in that there are effectively 2 separate change over relays in one package. However a quick look at willow's wedsite shows something that may be suitable. I'll have a look at comparing the data sheets. Do you know if willow will deal with Joe Public wanting to order small quantities? This is the problem ive found with most of the large suppliers in this country - not interested unless you want to order thousands of them! Cheers Jon You could be part of a large company and need one or two to use in a prototype for a forthcoming product - you know the kind of thing..... Si Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 20, 2007 Author Share Posted September 20, 2007 :-) thats what i thought you'd say! Jon Quote Link to comment Share on other sites More sharing options...
