zulublue Posted September 21, 2007 Share Posted September 21, 2007 I will soon be looking for some new boots for my 90, I have used Grizzly Claws for the last 18 months which have been great off road but mega wheel wobble on road, so I am trying to find a common compromise. Obviously size does matter, my 90 currently runs Cooper 255x85x16 but I want to find out how much higher / lower they are to the 265x75x16 I had on my RRC I like the look of the Recip Trial, any comments? Quote Link to comment Share on other sites More sharing options...
Steve H Posted September 21, 2007 Share Posted September 21, 2007 Nominally your 255 should have been about 33" & similarly the 265s about 32 " but there is a fair variation from nominal figures (ie according to industry standards) & what you actually get. It seems that very aggressive Muds can be quite a bit bigger than nominal sizes hence the only way you can be totally sure is to measure or have measured on a case by case basis the tyres you want to compare. Sorry, its about as good as I can offer. Someone else might be able to post some sizes, it would help to know what brand your 265s were. Steve. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted September 21, 2007 Share Posted September 21, 2007 Can't help with the tyre type but This tyre size calculator site,might help. Pete. Quote Link to comment Share on other sites More sharing options...
zulublue Posted September 21, 2007 Author Share Posted September 21, 2007 Thanks guy's thats great, Pete that tyre calc is fantastic Quote Link to comment Share on other sites More sharing options...
Escape Posted September 24, 2007 Share Posted September 24, 2007 Steve had a very good point about different dimensions for tires with the same nominal size. Even sticking to the same brand, a MT usually has a bigger diameter then an AT. There are several sites offering exact dimensions, including most manufacturers and some retailers like offroadreifen As for the Recip Trials, 2 of my mates run them on their RRCs and are very pleased! Very good performance offroad and decent manners onroad. The large sidebiters really make a difference. The 235/85R16 is a good 32", which is the largest size they come in, IIRC. Otherwise, I would probably also run them instead of genuine Mickey Thompson Baja Claws. Greetz, Filip Quote Link to comment Share on other sites More sharing options...
suvvey Posted June 1, 2008 Share Posted June 1, 2008 What is the largest size tyre that you can fit to a standard set up 90? I've tried searching for it as I'm sure it must be covered many times over but this was the closest matching thread I could find I used to run my last 4x4 on 33x12.5s Kumho MT's which seemed almost unstoppable but I believe I can't quite get that large on the Defender without lifting or using spacers. I have been told that 235/85 R16's are about the limit but was hoping I could use 265/75's for the extra width B) Quote Link to comment Share on other sites More sharing options...
