Diff pinion backlash
white90
 Share
Glad you got it fixed and didn’t find any of the bolts rolling around in the housing :rolleyes: …………. I guess the real option is to get it pegged to stop the ‘twisting’ action that does much damage to the R&P ………….. and seems to loosen off the CW bolts.
On the last one I did, I found it very important to really clean and major degrease the threads (bolts and holes - I used neat thinners) before reassembly ……….. that does seem to make the loctite hold together better.
Ian
I used thinners/brake cleaner
then an airline then allowed while before assembly
and cleaned the bolts
loctite270 and torqued them up
Cheers James I'll rtn the bits asap
Anyone know why they come loose and have any suggestions for preventing the same thing happening
Hi Tony, it doesn't seem to be uncommon on Land Rovers fitted with large mud tyres. I suppose it may be a combination of torque load and possibly a certain vibration frequency at speed on the road. Some Land Rovers suffer from the drive member bolts coming loose too.
I seem to remember that the series 2a landrovers (possibly on other models too) had a lock tab plate with two holes fitted under each pair of crownwheel bolts. Once the bolts were tightened, you knocked the flats of the washer onto the bolt head flats and so locked one bolt to its neighbour via the plate.
These are/were genuine parts and are probably still available. You could use these together with locktite.
Regards
Diff
Hi it is worth while adding do not overtighten the crown wheel bolts, common error, once past the elastic limit the bolts stretch and effectively become loose. The tab washer was used on the series vehicles with 3/8 BSF bolts but is 'soft' and under load deforms again ending up with 'loose' bolts when rover went to 3/8 unf they added a 'hardened ' washer. Do not overtighten, use a good thread lock on clean bolts.
Regards
Ian Ashcroft
 Share
