Daniel TD5 Posted September 23, 2007 Share Posted September 23, 2007 its bleeding to death its all over the road engine bay help power sterring looks low but that all i can see as its all got oil over it any idears checked engine oil ok power steering low as it got a oil cooler ? dan Quote Link to comment Share on other sites More sharing options...
western Posted September 23, 2007 Share Posted September 23, 2007 check the pipes/hoses for leaks, maybe chaffed by a securing clip. Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted September 23, 2007 Author Share Posted September 23, 2007 its leaking from the power steering pipe its hand tight dan Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 23, 2007 Share Posted September 23, 2007 Excellent LR build quality there.... i wonder what else is hand tight? suspension? brake pipes? Quote Link to comment Share on other sites More sharing options...
western Posted September 23, 2007 Share Posted September 23, 2007 its leaking from the power steering pipe its hand tight dan hope it's spanner tight now & stopped leaking Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 23, 2007 Share Posted September 23, 2007 help Call Land Rover Assistance and leave it up to them. Steve Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted September 23, 2007 Author Share Posted September 23, 2007 yep land rover assistance came out sub contract guy got under and tightened the pipe up need to get some fluid stuff in the morning to top up washed the wifes car this morning so did not see the leak untill the ground dryed out popped out and when i came back must have sprayed the drive with power steering fluid all fixed now dan Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted September 23, 2007 Share Posted September 23, 2007 Surely if they came out and fixed the problem they should of topped up the fluid as well to prove the system. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted September 23, 2007 Share Posted September 23, 2007 Surely if they came out and fixed the problem they should of topped up the fluid as well to prove the system. Agreed, it's not up to you to do it. Quote Link to comment Share on other sites More sharing options...
Daniel TD5 Posted September 24, 2007 Author Share Posted September 24, 2007 i would say he should have filled it up but he did not have any its going in wednesday to the stealers for the front lights so they will sort it out then i would say it needs checking dan Quote Link to comment Share on other sites More sharing options...
