flatback90 Posted September 25, 2007 Share Posted September 25, 2007 my s3 box is donald ducked and i have a choice of a 69 s2 box or an 83 s3 box which would you fit? are there any mods to fit the earlier box or are the later s3 boxes better? Quote Link to comment Share on other sites More sharing options...
RPR Posted September 25, 2007 Share Posted September 25, 2007 Depending on the individual condition of each, i.e. all other things being equal, I would opt for the 83 SIII box. It's a straight bolt up replacement. Have you got a suffix letter on it? If it's a D suffix, it's the best/strongest of the SIII lot. You can use the crash box and there are a couple of threads available off the search button explaining how to mod the clutch slave cylinder. You lose synchro and need tp pick up double de-clutching. While not terrifically inconvenient, I would still go with the SIII box unless the crashbox is in much better shape. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted September 25, 2007 Author Share Posted September 25, 2007 am told both are good was kinda erring toward the series 3 my thinking being surely they improved it towards the end of its run. thanks rpr will go and pull it out later. Quote Link to comment Share on other sites More sharing options...
