Francis Posted September 26, 2007 Share Posted September 26, 2007 Ok, here are my problems. 1) Full beam lights, keep blowing the 30 amp fuses. 2) Rear electric windows do not work (won't go up and down). 3) Reversing lights do not work. 4) Back door lock does not lock with the others on the central locking. 5) ARGH!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks in advance. If anyone is feeling generous, I'd appreciate some help in sorting this out. Even if it costs me 20 quid in beer tokens. I live in Crawley, and I am no longer a 'Defender' owner. It's a 1992 Disco 200 Tdi. Quote Link to comment Share on other sites More sharing options...
Guy H Posted September 26, 2007 Share Posted September 26, 2007 Ok, here are my problems.1) Full beam lights, keep blowing the 30 amp fuses. 2) Rear electric windows do not work (won't go up and down). 3) Reversing lights do not work. 4) Back door lock does not lock with the others on the central locking. 5) ARGH!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks in advance. If anyone is feeling generous, I'd appreciate some help in sorting this out. Even if it costs me 20 quid in beer tokens. I live in Crawley, and I am no longer a 'Defender' owner. It's a 1992 Disco 200 Tdi. 1. most probably a wiring issue either up front (most likely) or under dash. Have a good look for where the wires to the headlights go through holes in the body where the wires could chafe. 2. Could be rear window isolation switch, or anything in the circuit from fuse onwards (fuse, switches (inc. rears), relays, bad connection) have you got a RAVE CD or Haynes with the wiring diagrams? 3) check wire coming from switch on gearbox, my one had come loose. If ok check for 12v on one wire with ignition on and 12v on both when in reverse (I think the 200 has switched +ve), if ok check rest of wiring to bulb, bulbs & gnd on other terminal of bulbs. 4) Nor did mine, dodgy solenoid was the problem - I think I've got a spare working one in the garage I'm only in Coulsdon & quite happy to pop down (or you pop up) and give you a hand but prob not this weekend PM me if interested, have tools RAVE CD & 200tdi Haynes & a 200tdi being broken in the front garden lol. HTH Guy Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted September 26, 2007 Share Posted September 26, 2007 Rear lock may well just need stripping and cleaning - they're amazingly effective at collecting road grime... Quote Link to comment Share on other sites More sharing options...
lynall Posted September 27, 2007 Share Posted September 27, 2007 I could be wrong but i remember the 200 having fusible links in the loom near the battery. My last 200 melted the plugs on the back of the headlight bulbs, may be the same on yours? Lynall Quote Link to comment Share on other sites More sharing options...
GBrown Posted September 27, 2007 Share Posted September 27, 2007 Are you running spotlights with your full beam, if so are they fed through a relay? Quote Link to comment Share on other sites More sharing options...
