bathtub Posted September 27, 2007 Share Posted September 27, 2007 Hi pips, Anyone got the spigot type 4 bolt thingy that bolts on the back of a Rover V8 to locate a 3 speed Torque flight torque converter up ????? Someone fitted my last 2 boxes with the male part missing so that would explain why it eat the last two boxes in 2 weekends. What was it i was saying about paying a professional to do the big jobs {ps wasnt Bryn } Urgently needed please ready for Ireland. Quote Link to comment Share on other sites More sharing options...
pugwash Posted September 27, 2007 Share Posted September 27, 2007 I might have, but i'm not 100% sure what bit you mean. do you want the flexplate, a converter that bolts between the crank and the flex plate (which i wasn't actually aware of), the torque converter, the adaptor ring that sits between the bellhousing and engine block, or another bit. I think that i still have the flex plate and TC sitting around- so i might haev some bits bolted to the TC! i had 3 Tf727 that i got rid of recently- still have some bits and bobs lying around. Might be worth posting on Mez Forums as i know of a couple of people on there who use torqueflites. Otherwise try PM'ing gmc62landy on ORRP as he was the chap that bought my last load of bits. Quote Link to comment Share on other sites More sharing options...
bathtub Posted September 28, 2007 Author Share Posted September 28, 2007 I might have, but i'm not 100% sure what bit you mean.do you want the flexplate, a converter that bolts between the crank and the flex plate (which i wasn't actually aware of), the torque converter, the adaptor ring that sits between the bellhousing and engine block, or another bit. I think that i still have the flex plate and TC sitting around- so i might haev some bits bolted to the TC! i had 3 Tf727 that i got rid of recently- still have some bits and bobs lying around. Might be worth posting on Mez Forums as i know of a couple of people on there who use torqueflites. Otherwise try PM'ing gmc62landy on ORRP as he was the chap that bought my last load of bits. Its the bit that looks a bit like a hub flange IT bolts to the back of the crank shaft with 4 bolts & locates into the crank shaft !!!! Sort of anyway Thanks Peter Quote Link to comment Share on other sites More sharing options...
white90 Posted September 28, 2007 Share Posted September 28, 2007 Pete is it in this pic? if it is part number 6 it is FRC7075 Quote Link to comment Share on other sites More sharing options...
Mark90 Posted September 28, 2007 Share Posted September 28, 2007 Tony, isn't that for a 4 speed auto? Not sure the 3 speed one is quite the same. Quote Link to comment Share on other sites More sharing options...
white90 Posted September 28, 2007 Share Posted September 28, 2007 no idea Mark really was trying to assist Pete in ID' ing the item he wants Quote Link to comment Share on other sites More sharing options...
Mark90 Posted September 28, 2007 Share Posted September 28, 2007 Fair enough. Does Microcat cover pre1986 RRC when the TF727 3 speed auto was fitted? Quote Link to comment Share on other sites More sharing options...
white90 Posted September 28, 2007 Share Posted September 28, 2007 no it starts from 1986 Quote Link to comment Share on other sites More sharing options...
bathtub Posted September 28, 2007 Author Share Posted September 28, 2007 Pete is it in this pic?if it is part number 6 it is FRC7075 Thanks for that but yer thats a 4 speed diagam . The bit i need is the 3 speed one which is similar to the part betweeen the flex plate & the ring gear on your diagram Thanks peter Quote Link to comment Share on other sites More sharing options...
RPR Posted September 28, 2007 Share Posted September 28, 2007 I would imagine it would be available from Ashcrofts. Quote Link to comment Share on other sites More sharing options...
