Steve Warman Posted September 28, 2007 Share Posted September 28, 2007 I have a 1988 2.5 petrol 90 and use it to make runs to the tip or go down our allotment. However, the other day needed to go somewhere down the motorway. I've found my 90 makes up it's own speeds and that's fine with me and usually coast along at 65 without a problem. But living in High Wycombe (based in a valley) it can get a bit hilly and I noticed that as I was going along the motorway I started going up quite a log hill, nothing too steep, and the car just started to slow down. The engine seemed to rattle a bit more as it found the going a bit harder but I was surprised just how slow we ended up going. We got to the top of the hill, levelled off and the speed came back. I know it's old and I don't expect wonders but does it sound like there's anything seriously wrong with it or is there anything I can do to try and remedy it short of replacing the engine? Thanks Steve Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 28, 2007 Share Posted September 28, 2007 Major engine work can be uneconomical when alternative engines are so cheap. Try servicing it first - oil, filters, plugs, cap, arm, check & adjust anything that the book says you should adjust (timing, tappets, carb) and see if it improves. For the sheer bloody mindedness of it, I'd like to see someone supercharge one of those engines... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 28, 2007 Share Posted September 28, 2007 You mentioned that it "rattled", could it be pinking.... check the ignition timing. Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 28, 2007 Author Share Posted September 28, 2007 Major engine work can be uneconomical when alternative engines are so cheap.Try servicing it first - oil, filters, plugs, cap, arm, check & adjust anything that the book says you should adjust (timing, tappets, carb) and see if it improves. For the sheer bloody mindedness of it, I'd like to see someone supercharge one of those engines... Thanks Fridge, I was thinking about changing the filters and a few other bits anyway so I'll see how it goes. I'm trying to avoid big expense bills as it was only cheap in the first place Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 28, 2007 Author Share Posted September 28, 2007 You mentioned that it "rattled", could it be pinking.... check the ignition timing. Yeah, it tends to rattle a bit when it's going up hills, a fairly high pitched rythmic rattle like it's straining in the gear it's in Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 28, 2007 Share Posted September 28, 2007 Make sure you do *all* filters, a blocked fuel filter can really b*gger things up and most people don't change them... ever Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 28, 2007 Author Share Posted September 28, 2007 Make sure you do *all* filters, a blocked fuel filter can really b*gger things up and most people don't change them... ever Right o, I'm replacing the rear cross member soon so the I can do it at the same time as the other half won't want me to go shopping if she knows I'm playing mechanic Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 28, 2007 Share Posted September 28, 2007 The old petrol engine doesn't have a lot of torque and so isn't great on long hills but it does sound to me as if it is pinking from the description you give. My old 2.5P 90 used to do the same. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 28, 2007 Share Posted September 28, 2007 Would it be too predictable for me to suggest fitting EDIS to it? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 29, 2007 Share Posted September 29, 2007 Would it be too predictable for me to suggest fitting EDIS to it? Yes Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 30, 2007 Author Share Posted September 30, 2007 Can I ask what an EDIS is and why is predictable? Thanks Quote Link to comment Share on other sites More sharing options...
