part help
frrfrr
Hi Fraser,
I assume that you are referring to the metal strips with the now non existant M6 mild steel coach bolts ?
You should pm Weston on this forum for a part number if you wish to replace with genuine. Otherwise, you could make up some replacements using 25mm x 6mm mild steel or stainless flat bar. If you use stainless fasteners, you will also be able to get them off again in future. :)
Another possible tip - I changed my RRC rear mudflaps for 110 rear flaps and cut to suit. The 110 flaps are much harder wearing material, and will not snap off like classic ones tend to.
Adrian.
hi , its not the strips , but the whole piece thats rotten. they fix on the underside of the shell and the flaps fix on to them . i asume that they stop water etc from splashing up when driving . they measure roughly 8x8 inches
thanks fraser
