alan kemp Posted October 4, 2007 Author Share Posted October 4, 2007 Alan, As far as I know mine are std backspace which are 3 3/4" and it works really well apart from they stick out about an inch either side of my trailer! Thought you were after 3" backspace The way I understood it to work would have been a shollower inner dish and 1 1/2" wider overall, not narrower! Quite possible I could be wrong tho, The Mrs says I usually am!!!! It depends who you talk to, my "offset" was based on 3" from the outside of the wheel on a 8" wheel, so this would be 5". With these wheels I will have a lot more clearance on the radius arms with a backspace of 3.75 but the truck will be stupidly wide Quote Link to comment Share on other sites More sharing options...
Chris Abel Posted October 4, 2007 Share Posted October 4, 2007 I'll agree that they dont leak, Put mine together without sealant, Just a bit of tyre soap and none of them leak!Alan, As far as I know mine are std backspace which are 3 3/4" and it works really well apart from they stick out about an inch either side of my trailer! Thought you were after 3" backspace The way I understood it to work would have been a shollower inner dish and 1 1/2" wider overall, not narrower! Quite possible I could be wrong tho, The Mrs says I usually am!!!! My volvo rims that i cut the centre's out of and rewelded have a 5 1/2 inch backspace (back of rim to face of hub), ive welded beadlock rings on so my rims are 9" wide, my truck is 7ft wide with the 37/14.5/16 iroks. Are you sure that you want to make yor truck 7' 4" wide? Quote Link to comment Share on other sites More sharing options...
