Les Henson Posted November 1, 2005 Share Posted November 1, 2005 I finallly bolted the 'good as new' head back on catflaps engine this afternoon. New hotspots, new pegs (yes they are a B*^*)(%d to get out. Everything is cleaner than a clean thing, including the rocker shaft, rockers, fiddly little things that go on the top of the valve stems etc etc Ennywahey the head bolts torque setting is 91 ft lbs. I have NEVER seen a torque wrench that has 1 ft lb increments. Just thought I'd have a bit of a moan Les. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted November 1, 2005 Share Posted November 1, 2005 Well mine doesn't either, it only has 1Nm increments Quote Link to comment Share on other sites More sharing options...
white90 Posted November 1, 2005 Share Posted November 1, 2005 Mine does, Sealy one from 10-150ft/lb in 1lb increments Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 1, 2005 Share Posted November 1, 2005 Les You use 90lbft and then half a grunt for the extra 1 Quote Link to comment Share on other sites More sharing options...
western Posted November 1, 2005 Share Posted November 1, 2005 No torque wrench is that accurate, at work we have to use the torque analyser to set them before use, I reckon if you set it at 90 and give it a extra tug, it'll work fine Quote Link to comment Share on other sites More sharing options...
Paul Posted November 1, 2005 Share Posted November 1, 2005 No torque wrench is that accurate, at work we have to use the torque analyser to set them before use, I reckon if you set it at 90 and give it a extra tug, it'll work fine Nah. Do it up 'til it strips, then give it it 'nutha half a turn. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 1, 2005 Author Share Posted November 1, 2005 You're not being very helpful Paul! Les Quote Link to comment Share on other sites More sharing options...
john cranfield Posted November 2, 2005 Share Posted November 2, 2005 I suspect the Ftlb figure is converted from another unit of measurement, Newton/meters or gerbil/antelopes or somesuch. John Quote Link to comment Share on other sites More sharing options...
cols110 Posted November 2, 2005 Share Posted November 2, 2005 I think the proper way is to keep going till you snap something, split a few knuckles open, then do the rest to a bit less. Most of the ratchet type ones where you tighten the handle up to increase tension are usually graduated in 1ft/lb increments. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted November 2, 2005 Share Posted November 2, 2005 Do it up to 1ft-lb, then 90ft-lb... the bolt will add them together mechanically... Quote Link to comment Share on other sites More sharing options...
