wow300 Posted October 3, 2007 Share Posted October 3, 2007 As above, cant find it anywhere ! ? Quote Link to comment Share on other sites More sharing options...
dougstar Posted October 3, 2007 Share Posted October 3, 2007 right here goes.............. open the two flat head screws situated under the steering collum let the door drop down you should see on the right hand side a bank of fuses 6 vertical across the top (satellite 2) 17 horizontil across the middle (main fuse box) 6 vertical across the bottom (satellite 1) head for main fuse box No 6 this is the 6th horizontil fuse on the left as you look at the panel thats your ciggy lighter SH!T just realised you posted this on the RR forum! let me know what year and model it is and i'll find it for you hopefully dougstar Quote Link to comment Share on other sites More sharing options...
wow300 Posted October 3, 2007 Author Share Posted October 3, 2007 1993 classic cheers Quote Link to comment Share on other sites More sharing options...
dougstar Posted October 3, 2007 Share Posted October 3, 2007 ok here goes again........... try fuse number 17 should/would have been a yellow 20a incorporating ciggy lighter (front and rear) and gear selector indicator hppe this works its out of a manual for a 87-91 but hopefully the same?????????? let me know. dougstar B) Quote Link to comment Share on other sites More sharing options...
Big Gaz Posted December 1, 2007 Share Posted December 1, 2007 Just bought an 02 L322 V8. The cigar lighters do not work and have checked fuses in glovebox drop down and all ok but none are labelled as cigar lighter. Does anyone know if there is another fusebox I could try? Many thanks. Quote Link to comment Share on other sites More sharing options...
