BoatBuoy Posted October 4, 2007 Share Posted October 4, 2007 I have a set of G90s on the works 110, yeah I know... The back left tyre has worn a bit funny. On the outer edge of tyre, the trailing edge of the tread blocks look to be scrubbed down.The front edge of the blocks look new and the backs almost worn away. Why? I had the tracking / alignment done a while back, and the tyres are at the book pressure. I had similar on both fronts, but got the tracking done and the latest fronts seem ok. Quote Link to comment Share on other sites More sharing options...
western Posted October 4, 2007 Share Posted October 4, 2007 rears are probably being worn like that due to worn trailing arm bushes allowing the axle to do a bit of rear steering. with a good load on the rear tyres should be around 40 to 48psi. Quote Link to comment Share on other sites More sharing options...
nas90 Posted October 4, 2007 Share Posted October 4, 2007 I have a set of G90s on the works 110, yeah I know... The back left tyre has worn a bit funny. On the outer edge of tyre, the trailing edge of the tread blocks look to be scrubbed down.The front edge of the blocks look new and the backs almost worn away. Why? I had the tracking / alignment done a while back, and the tyres are at the book pressure. I had similar on both fronts, but got the tracking done and the latest fronts seem ok. Now if you had a R1 then a classic example of using too much right wrist, too much knee down and definitely a big grin factor all in reverse . Not sure how you managed that in a 110, must be trying too hard Quote Link to comment Share on other sites More sharing options...
GBMUD Posted October 5, 2007 Share Posted October 5, 2007 Agressive LR tyres often wear like that. I think that I have heard that low pressures can have a bearing - the tyres (Michelin XZLs) on my ex-army trailer have a similar wear pattern. Chris Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 5, 2007 Share Posted October 5, 2007 I've been told that this can be casued by knackered shocks. Jon Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted October 5, 2007 Share Posted October 5, 2007 I've been told that this can be casued by drifting. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 6, 2007 Share Posted October 6, 2007 I've been told that this can be casued by drifting. I was just thinking the tyres on the 109 are wearing like that... Quote Link to comment Share on other sites More sharing options...
BoatBuoy Posted October 6, 2007 Author Share Posted October 6, 2007 I was just thinking the tyres on the 109 are wearing like that... Hmmm... well had a look under and couldn't see any worn bushes or loose bits... It's a td5 so you can't drive them too hard can you? Quote Link to comment Share on other sites More sharing options...
