Whats Your Limit
To All,
Aesthetic attachments aside, Im curious to find out where you draw the line when repairing or restoring with your pride and joy.
In the four years of owning my Defender 110, Ive replaced and repaired the following:
Gearbox, (reconditioned)
Refabricated/rewelded bulkhead
Replaced numerous gaskets
Clutch
Clutch Slave & Master Cylinder
Side & Tail Lights
Repainted inside and out, twice!!!
Speedo Cable
Outstanding Jobs:
Rear X-Member, (Think Ive covered this enough for next MOT)
Neg Earth Fault on lighting system
Replace Number Plate Light
Replace Fuel Filter Housing
I enjoy doing this very much, but I do wonder if there is light at the end of the tunnel.
Cheers :lol:
ok, I think this is going to scare me
<racks memory>
Fuel tank (Funny how that always springs to mind first - hateful job)
water pump
alternator
power steering pump
head lights (twice, moving countries)
clutch master & slave
front brake calipers
hub seals
radiator
lift pump
injectors
injection pump
hand brake
added a leccy fan
indicator switch
rear prop UJs
springs and shocks
CV
Door glass (I accidentally threw a screw driver through it - don't ask :blush: )
Wiper wheel box (dropped a boat on the wiper - same week as the screwdriver/window interface)
That's over about 6 years of blissful Land Rover ownership
To Do:
new doors
swivel overhaul
steering box
radius bushes
brake pipes
exhaust
fix some of the water leaks before winter :D
I look on it as a rather expensive lessons in mechanics.
Well I've had my 1988 90 for about a month now and I've done the clutch hydraulics and got a new rear x member sitting on my patio ready for me to cut out the old one, I've changed light bulbs, replaced the battery and have a few bump stops ready to be put on as well as an alternator belt as the old ones worn.
I've only just started on mine and I love it.
For future project I have to repair the bulkhead corners and door pillars and probably do the seatbox and footwells.
I'm going to keep going with mine till it dies on it's ass
I'm not going to write the list for mine - it'd take too long and it would scare me :ph34r:
Suffice to say in ~7 years I have gone from a standard tatty 109 to my present "classic restoration" :P via a few stops on the way, there's not much of the original left but it's still my 109 :wub:
I'd hate to add up how much I've spent on Land Rovers over the last 25 years :blink:
Only once did I give up on one, a 73 series 3 station wagon that was just too late to be tax free. After 2 engine and gearbox changes, it was needing serious chassis work for MOT. I gave up then and scraped it, selling parts for more than vehicle was worth and was surprised at how much I gat for the scrap ally
New chassis
New wings (complete)
New door bottoms
New door tops Military type)
Engine
Gearbox
Transfer box
New rad
New brake pipes
Goodridge hoses
Pas and complete steering system
Custom made grille
Custom made light guards
LED bulbs
New military lights
Disc brake front axle
Disc brake rear axle (soon)
New props
Parabolic springs
New footwells and door pillars
Reinforced rear crossmember
Defender type upper shock mounts
Halogen headlamps
etc.
Les.
There's a limit ? Why didn't anyone tell me ?
Doors, several
Wings, several
bonnet, a couple
Ashcroft gearbox
steering box
steering pump
steering hoses
rear crankshaft seal, twice
diff changes
clutch
lift pump
shocks
springs
timing belt, broken
new props
enough UJs to keep Paddocks solvent
clutch master and slave
clutch pedal change
rear cross member
radiator change
intercooler change, several
repaint
inlet/exhaust/turbo change
water pump
electric fans, several
brake discs and calipers
wheel bearings
output seals, many
diff input seals, many
hub seals, many
rebush, twice
injection pump rebuild
Nas light
work lights
front high driving lights, several sets, now given up on
tyres, on third set
and on and on over the last 6 years
I stopped keeping a running total when I became too embarassed to tell the wife but I have all my receipts still :)
There is no light at the end of the tunnel :)
Mo
Bulkhead repair
Footwell repair
Rear doors repair
Quick re-spray
Recon 3.5 Engine
Recon Transfer box
Part re-built gearbox
New clutch throuhgout
3.9EFI engine inserted (3.5 sold)
Replacement rear axle (Moved to rear disks)
Repairs to rear cross-member
New wheels & Tyres
New disks, calipers & pads on front
New pahnard rod bushes (Twice)
New springs all round
New shocks all round
Front Prop UJ's
Rear Prop UJ's
All bushes underneath changed to Poly
All track rod ends / Ball joints on front replaced
New PAS pump
New steering box
New steering damper
Replaced steering wheel
New water pump X2 (One for each engine)
Retro fit dash & new stereo fitted
New windscreen (now heated)
Porbably more too but forgotten...
Still to do....
Replace all body work, replace all doors
Replace chassis
Re-register on 57 plate
Oh... And only had this 110 for 18 months....
Needless to say, this was a cheap purchase.. Or that's how I justified to the Missus.. ;)
I've seem some of the work you have done on your vehicles MOG and it's outstanding - especially the ambulance.
You should post a list - we now have enough bandwidth :lol:
Les.
Thanks Les ;) The spankers new Defender is nice but I do need a new project ...SWMBO might have different ideas though :rolleyes:
Gearbox
Clutch
Clutch Slave
Clutch Master x2
PAS Box
PAS Pump (thanks JST)
Fuel Inj Pump
Props f&r
Rear Ball Joint
Alternator
Starter Motor
Water Pump
Hand Brake - to X-Brake
Springs & Shocks & Brake Pipes as part of lift
Bushes, seals, generally...
Track Rod bushes
Rear Door
In progress:
19J engine replacement to get to the Lake District......... Thanks Les.
To do:
Rear Crossmember
Chassis repairs
Well, look on the bright side, I haven't wasted any money on shiny new body panels!
...sigh
God I thought I was having problems lately
1996 300tdi 88000 mls (owned him for 3 years)
new clutch
new clutch salve cylinder
brake pads all round
exhaust
alarm spider
tyres twice
front hub seals
both front window lifts
ns front indicator (stupid women with a shopping trolley :angry: )
Thanks guys you've made my day my landy's not as bad as some :D
I’ve had my car seven years and this list just scared me. It all seems reasonable when you’re looking at one more job to do:
Driveline:
PAS pump swap
2.5NAD rebuild
300Tdi/R380 conversion
1.2 LT230 swap
Swap the R380 for one with a mainshaft in it
2x 24spline axles and discs etc
Props plus innumerable UJs.
Then popped a diff so went for a TruTrac.
Then go 4HP22 auto with 1.4 t-box
The 300Tdi has had 2 water pumps and at least 3 alternators.
The NAD used a rad and a couple of alternators too.
The rear chassis has been replaced
The rear tub has been replaced
It’s had three fuel tanks.
Four springs and at least eight shocks with four more planned
Bushes galore
Now I’m planning a 1.2 t-box behind the auto once I’ve rebuilt it.
Both front doors are shot
The bulkhead needs doing
Let’s not forget servicing too…
Mine’s now on 230k miles, seems I’m not quite there yet. The speedo is the only rotating part that’s reached that mileage though….
Well ignoring the trivia (and Fridge's cast offs) I'm now on:
engine (twice)
transfer box
rear axle
front axle (excluding case)
bulkhead
spring/shocks (twice)
diffs
Simex (twice)
Still to do is the chassis and some twisted body panels. :rolleyes:
300tdi 90 - owned it for 5 years, rtv and playdays every month and my daily driver with approx 10k miles a year.
1 diff,
1 half shaft,
1 rocker shaft and pushrods after a snapped cam belt
1 water pump
copies amounts of alternators (deep wading), wheel bearings, prop UJs, brake pads and tre's - but i consider them service items.
thats it.
although if i were being thorough - its needs a new body as its getting a bit battered and dented now. But i wont do that cos i'd get upset the first time i lay down in a gully and dented/scratched down the whole side.......
