zulublue Posted October 5, 2007 Share Posted October 5, 2007 I have changed the block in my 92 Defender and put a disco block in, does anyone know if the sumps are different? reason for the question is that the dip sticks are different lengths and I wanted to put the engine back to as original as possible, but noticed when I put the dipstick in it the oil was miles above the high limit, so I lifted the outer casing as high as possible, I then added 6.8L of oil as suggested and measured it again, it was twice over the high mark, any ideas? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 5, 2007 Share Posted October 5, 2007 Use the dipstick that matches the sump to state the obvious. Quote Link to comment Share on other sites More sharing options...
western Posted October 5, 2007 Share Posted October 5, 2007 200Tdi engines in Defender & Discovery are fitted with the same sump so EPC shows me, ERR1790, are you using the Discovery or existing dipstick ? the dipstick outer tube can slip down & show a false high oil level reading, reckon that is the problem, remove the outer tube & open out the lower end a bit more so the little brass olive sits tightly, you should be able to see the mark on the tube where the olive should be to give correct oil level readings. I used a pair of long nose pliers to reflare the end of the dipstick tube, just put the closed tip of the pliers in & rotate the tube to reflare the end. Quote Link to comment Share on other sites More sharing options...
zulublue Posted October 5, 2007 Author Share Posted October 5, 2007 Use the dipstick that matches the sump to state the obvious. Phil due to the inlet manifolds been different it was better to dit the dipstick from the defender. western I will give it a try, but I think it fits snug Can anyone confirm the how many litres the engine takes, is it 6.8L for the Defender and Disco? 200TDi Quote Link to comment Share on other sites More sharing options...
western Posted October 5, 2007 Share Posted October 5, 2007 2000Tdi is 6.85 litres of engine oil with a new oil filter fitted Quote Link to comment Share on other sites More sharing options...
zulublue Posted October 5, 2007 Author Share Posted October 5, 2007 Cheers, I will re check it. Quote Link to comment Share on other sites More sharing options...
