66gaza Posted October 6, 2007 Share Posted October 6, 2007 Hi, I need a bigger bore clutch master cylinder as my 3/4" doesn't move my new slave far enough (yank box). I have looked and the series used a 7/8" and some a 1 1/8" for a brake master, these are single circuit . My slave is 1" and as far as I can find out has to move atleast 1" to operate clutch. So has anyone used one in a defender?. I appreciate the smaller the bore the less pressure is required but the longer the stroke has to be. The vehicle the clutch came from has a 7/8" bore but I don't know how much stroke. I will probably try the 7/8" first and if that doesn't work will try the bigger one, If they fit in the available space. So what do you all think? Gaza Quote Link to comment Share on other sites More sharing options...
66gaza Posted October 7, 2007 Author Share Posted October 7, 2007 I thought I would bump with a pic, I need a clutch master then I can drive it. needs to be atleast 7/8" bore. After that I Just need to tidy the wiring up a bit and a few other bits and bobs. Gaza Quote Link to comment Share on other sites More sharing options...
66gaza Posted October 8, 2007 Author Share Posted October 8, 2007 Does any one know what CB (compression barrel) means in relation to a S2 master cylinder? these are the ones with a big nut at the back. Gaza Quote Link to comment Share on other sites More sharing options...
