dirtydiesel Posted October 10, 2007 Share Posted October 10, 2007 James Thanks for the note and photos would like to see it on the truck Mr Diesel questions for you I have a straight through exhaust - so the pto can be clocked over this also have a x disc hand brake the leaver will clash - I expect this can be bent to suit another thing is that that theres a square part on top mates with the same on gearbox I think what happens with this or is it not a problem? Sorry for the hyjack Steve Hi Steve, The x brake cable mount can be altered to clear the pto, the square hole in the top is not an issue, The only problem i've encountered is that on the later lt230's there is an oil feed hole in the back face of the transferbox, this is normally obscured and blanked by the pto mounting flange but when the pto is clocked the oil way is in line with one of the old mounting holes this hole either needs blanking or welding up. If you can wait until late next week i'm fitting a H14 and clocked pto to a customers car so i could take some pics if you wanted? Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted October 11, 2007 Share Posted October 11, 2007 Hi Steve, The x brake cable mount can be altered to clear the pto, the square hole in the top is not an issue, The only problem i've encountered is that on the later lt230's there is an oil feed hole in the back face of the transferbox, this is normally obscured and blanked by the pto mounting flange but when the pto is clocked the oil way is in line with one of the old mounting holes this hole either needs blanking or welding up. If you can wait until late next week i'm fitting a H14 and clocked pto to a customers car so i could take some pics if you wanted? That would be great to have a look at the photos I can wait I'm in no hurry - if you were closer I think I would get you to do mine for me ! Steve Quote Link to comment Share on other sites More sharing options...
jameslwt Posted October 13, 2007 Author Share Posted October 13, 2007 That would be great to have a look at the photos I can wait I'm in no hurry - if you were closer I think I would get you to do mine for me !Steve Steve Sorry it's taken a few days but here are some piccies of my PTO guard attached if you decide to not go down the clocked pto route. Regards James (ignore the shocking welding on the brackets!) ....and maybe I shoiuld get round to changing the threaded bar to bolts...all I had at the time) Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted October 13, 2007 Share Posted October 13, 2007 James Thanks for the photos Steve Quote Link to comment Share on other sites More sharing options...
