white90 Posted October 11, 2007 Share Posted October 11, 2007 Mantec failed to respond to repeated calls I need 2 washers/spacers that fit under the frame of the wheel carrier on the mountings like very large thin washers any ideas on where I can get some approx .5mm thick 40mm dia Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted October 11, 2007 Share Posted October 11, 2007 Are these plastic washers Tony? If they are may I be able to sort you out? Quote Link to comment Share on other sites More sharing options...
white90 Posted October 11, 2007 Author Share Posted October 11, 2007 Thanks Kevin but I'm sure they were metal before I lost them at Slindon they are part number 21 on the instructions if you have them Quote Link to comment Share on other sites More sharing options...
nas90 Posted October 11, 2007 Share Posted October 11, 2007 Thanks Kevinbut I'm sure they were metal before I lost them at Slindon they are part number 21 on the instructions if you have them Tony, pm me and we can send you some laser cut washers, stainless steel? Ø40xØ?xthk0.5mm Quote Link to comment Share on other sites More sharing options...
darthdicky Posted October 11, 2007 Share Posted October 11, 2007 If you're stuck I've got some of those Tony, found them the other day somewhere. They sent me some spare bits to cure a squeek but I didn't need those washers. Richard Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 11, 2007 Share Posted October 11, 2007 If you can, get some PTFE or nylon washers. Quote Link to comment Share on other sites More sharing options...
white90 Posted October 11, 2007 Author Share Posted October 11, 2007 Thanks all DD has saved te day and is sending some over thanks again Quote Link to comment Share on other sites More sharing options...
