acwid Posted October 11, 2007 Share Posted October 11, 2007 Hey up folks newboy here , need advice on best front shocks for 200tdi do not need to be performance quality just good value , gas or oil which is best many thanks . Quote Link to comment Share on other sites More sharing options...
q-rover Posted October 12, 2007 Share Posted October 12, 2007 Standard ones would be hard to beat, or you could try Pro-Comp or the new Britpart range. Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted October 12, 2007 Share Posted October 12, 2007 Hey up folks newboy here , need advice on best front shocks for 200tdi do not need to be performance quality just good value , gas or oil which is best many thanks . I won't say too much as I am biased but I can sort you out a great Forum member offer on a pair of Rough Country ones ( IMJO the best value gas ones ) Having said that if all you want is cheap that work fine then get onto Craddocks / Paddocks etc. for a pair of standard ones.... David Quote Link to comment Share on other sites More sharing options...
acwid Posted October 12, 2007 Author Share Posted October 12, 2007 Many thanks chaps think I will stick to the standard shocks ,are there any tips you can give me to help the refit go a bit smoother apart from get someone else to do it cheers. Quote Link to comment Share on other sites More sharing options...
Litch Posted October 12, 2007 Share Posted October 12, 2007 This is one of those questions where every owner will give different advice depending on what they have fitted themselves. I use De Carbon gas shocks and find them very good but if you aren't looking for any kind of performance increase then stick to what LR specified when they designed the vehicle as they are more than up to the job and are a fraction of the cost of any aftermarket ones. Quote Link to comment Share on other sites More sharing options...
