landybehr Posted October 31, 2007 Share Posted October 31, 2007 IIRC the alternator-charge-wire goes to the solenoid. From there two more wires continue - one going to the firewall (12V supply for the entire vehicle) and another to the battery. So ignition is ruled out. (?) I think it´s worth to replace the condensor. They probably don´t go wrong often, but IIRC they have a service life. And if faulty they, so I think, can "leak" down current away from the ignition coil. Which, in turn, causes weak sparks. Quote Link to comment Share on other sites More sharing options...
paintman Posted November 1, 2007 Share Posted November 1, 2007 EFi distributors don't have condensors. Quote Link to comment Share on other sites More sharing options...
DC_ Posted November 1, 2007 Author Share Posted November 1, 2007 IIRC? condenser? See now your talking that tech talk again lol. Anyhoo.............................Yesterday i got time to take the leads off the solenoid. Took an age to get into it but i got there with sore arms, wet and dry sandpaper i cleaned the end of the leads and sprayed the top of solenoid with contact cleaner (great stuff that) Packed the terminals up with petroleum jelly and reconnected.........................................Battery went in after a good charge, started first time and i checked with new multi meter, getting 14.20 volts now going to battery Even the starter motor is sounding a lot stronger but it is making a bit of a groan when it's turning. So ALT problem hopefully sorted. Next to do is give it a run and see if it's still running rich or rough. Then at least i have 2 options to try sort that.........................stepper motor open all the time....................and or, engine coolant sensor begubbed. Any thoughts welcome DC (happy still) Quote Link to comment Share on other sites More sharing options...
