Tony Carter Posted October 15, 2007 Posted October 15, 2007 Hi: First time here. I have a 1988 3.5EFI. Regarding the fuel evaporative unit under the offside rear wing. I am sure I read somewere many years ago that its not really needed. Can anyone advise ? (I am only thinking of removing it if its not nessesary as I am in the middle of changing the rear crossmember and noticed a lot of hardened or split rubber hoses and rusty circlips) Quote
Ivan Posted October 16, 2007 Posted October 16, 2007 I have a 1991 V8i Discovery and I removed it completely and it's made no difference. Rgds Ivan Quote
Tony Carter Posted October 17, 2007 Author Posted October 17, 2007 I have a 1991 V8i Discovery and I removed it completely and it's made no difference.Rgds Ivan Quote
Tony Carter Posted October 17, 2007 Author Posted October 17, 2007 I have a 1991 V8i Discovery and I removed it completely and it's made no difference.Rgds Ivan Hi Ivan: Thanks. Has your Discovery been MOT'd since you removed it ? and did you seal all the pipes, or did you need to leave any open for air to get in the tank? Quote
Ivan Posted October 17, 2007 Posted October 17, 2007 Hi Ivan:Thanks. Has your Discovery been MOT'd since you removed it ? and did you seal all the pipes, or did you need to leave any open for air to get in the tank? Tony It's been through a number of MOT's and no problem. I would either seal the pipes or leave them open as extra breathers. Mine was removed because I fitted a 300 Series ES Diesel body to it. I think they were fitted for fuel evaporation in some countries. Something about not letting surplus fuel evaporate into the air. Ivan Quote
Tony Carter Posted October 18, 2007 Author Posted October 18, 2007 TonyIt's been through a number of MOT's and no problem. I would either seal the pipes or leave them open as extra breathers. Mine was removed because I fitted a 300 Series ES Diesel body to it. I think they were fitted for fuel evaporation in some countries. Something about not letting surplus fuel evaporate into the air. Ivan Ivan: Many thanks for the advise: Its coming off, and I will block the pipes up. Quote
