Posted
hey their am going to be doing my uncles disco timing belt , its a 300tdi only problem i have is that i have a mac so no microcat installed just wondering if anyone has the specific parts number need to do ie,
  • timing belt plus new pullys
  • crankshaft oil seal
  • timing chest cover seal
  • gaskets
  • and any other item i may require
thanks
Posted
I guess your uncle's 300tdi doesn't fall in the ranges listed here: http://forums.lr4x4.com/index.php?showtopic=12788 or the mods were done at some point of its life.
Many people use the kit showed in the 1st picture of this thread: http://forums.lr4x4.com/index.php?showtopic=6943
What u can see in that picture is [the #s in brackets are pos in the picture below]:
STC4096L [11+24+2+4+5+6+7+8+9] timing kit
ERR4575(G) [18] crankshaft front oil seal
ERR7143(G) [15] crankshaft timing cover seal
These are the min recommended bits.
Depending on your choice and/or state of the parts, you might consider replacing:
ERR3356(G) [17] camshaft oil seal
ERR4710 [10] crankshaft o-ring
ERR5215 [3] woodruff key
(G) means that u can get the genuine part (recommended) ERR4575G or OEM/aftermarket ERR4575.
Posted
"ERR7143(G) [15] crankshaft timing cover seal"
I thought it was ERR4576, not that we change them unless the case has the old metal seal.
Preferably get the kit from Bearmach not LR, STC4096K which will have a forged crank pulley not the spot-welded OEM LR one which falls to bits and takes your engine with it.
Posted
It's ERR7143 for VINs from VA560898
and ERR4576 for VINs up to VA560897
What I didn't like at the Bearmach kit was that there was nothing written on the bearings, I couldn't find anything about them.
At least the "L" kit I bought had NSK bearings.
Do you happen to have a spot welded crank pulley that you took out and shows some signs of wear or fell into pieces? I mean I take your word for this but it would be interesting to see one (and perhaps what mileage?).
Posted
thanks that what i need , i need to have a quick check the vins just to confirm , just wanted the stuff as i cant leave it with its throat cut at work
