Defender Posted October 16, 2007 Share Posted October 16, 2007 Hi does anyone have a picture they can post of a defender wearing some 35\12.50x15 BFG Muds? Thinking of an upgrade & I'd like to know how much I will have to cut out of the arches. I was also looking at the Maxxis creepy crawlers but no one seems to have any comment on what they are like in the mud...does anyone know please?!?!?!!? Thanks Quote Link to comment Share on other sites More sharing options...
D9OSV Posted October 17, 2007 Share Posted October 17, 2007 BFG muds are massively under rated, if you are looking for a tyre that has the best of worlds you will be hard pushed to beat it. I have not yet used the Creepy crawlers, however i will be gob smacked if they wear anything like as well the BFG's. Have not got any pics of 35's on a standard truck, but i have got some pics of them on Stefans Trayback (The vehicle with 5 on the side) When these pics were taken he was running BFG muds at 30psi and i was using Simex at 10psi, on the rocks there was no comparsion, the Muds drove circles round the aggressive Simex. http://www.devon4x4.com/forum/viewtopic.php?t=3509 Hope that helps a little Jim Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 17, 2007 Share Posted October 17, 2007 My project90 on 35's..... Had to trim the arches a little bit, but not as much as when i put the simex's on (although they do have masively offset rims) Quote Link to comment Share on other sites More sharing options...
Petergg Posted October 17, 2007 Share Posted October 17, 2007 Quite a few Here Peter Quote Link to comment Share on other sites More sharing options...
Defender Posted October 17, 2007 Author Share Posted October 17, 2007 Thats great thanks everyone! Pete Quote Link to comment Share on other sites More sharing options...
white90 Posted October 17, 2007 Share Posted October 17, 2007 I'd offer that they can be too wide, having seen a 90 shod with them fail to drive on a slippery slope that nearly every other car with BFG M/Ts drove(I have an old VHS vide of it somewhere, not sure how to get in on here) but with slimmer tyres, I suggest 255/85/16 are hard to beat on a defender. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 18, 2007 Share Posted October 18, 2007 ^^^^^^ what he said. my 90 was "ok" on 35's, but nothing great, i remember getting hoplessly stuck in a bit of slippery mud, and with both lockers in i was like a spider in a bath! (OK, they were at road pressures) but t he 35 was a bit too wide for the "light" weight of a 90. running 255's now, and they have just enough narrowness to dig in and grip. Quote Link to comment Share on other sites More sharing options...
nicksmelly Posted October 18, 2007 Share Posted October 18, 2007 Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted October 20, 2007 Share Posted October 20, 2007 another vote for 255/85x16s here. I have been very happy with the grippyness of them on my 110 in all conditions. I did come very close to getting embarassly stuck the day before yesterday, but then I had ventured a lot further than I should have when the front prop was leaning against the wall in our hallway Will Quote Link to comment Share on other sites More sharing options...
TomG Posted October 20, 2007 Share Posted October 20, 2007 I guess it depends on the sort of terrain you'll be spending most time on.. If it's a layer of slimy mush or slippery wet grass with firm ground / clay not far underneath then narrower aggressive tread tyres would be best to dig down into the firm. It's the grounds boggy and bottomless with a floating layer on top you don't want to break the crust so wide tyres aired down with a milder tread will pad over the top (lower ground pressure). On rocks & stumps, it helps if the tyre can deform to the shape of the rock, the carcass of the tyre needs to be flexible when aired down (though this tends to make for a weaker sidewall) I've used 35x12.5x15 MT's on my 90 for the last couple of years, find they do well in most conditions except firm wet grassy slopes. Just my 2p. Quote Link to comment Share on other sites More sharing options...
Defender Posted October 22, 2007 Author Share Posted October 22, 2007 I basically have been running 265/75 R16 all terrains on the road & swapping to 285/75 R16 Grizzly Claws for off road but I'm getting fed up with swapping tyres about so much. My idea was to run the BFG muds at 30psi on road & drop them to 10psi (Using bead locks) for off road use, hopefully giving me a compromise between on road & off road with one type of tyre. I need to sell my existing tyres before I can try the above so if anyone is interested in a set of alloys with all terrains or Grizzly Claws on silver modulars, check out my auctions on Ebay. Pete Quote Link to comment Share on other sites More sharing options...
sebbe Posted October 23, 2007 Share Posted October 23, 2007 Quote Link to comment Share on other sites More sharing options...
